cant lock my doors - JeepForum.com
post #1 of 3 Old 05-29-2006, 05:27 PM Thread Starter
louielawless
Junior Member
cant lock my doors
Am i the only one?I have a 97 tj some times even in 95 degree weather if i dare to lock my drivers door or my passenger door i cant open them from the outside with a key or even on the inside.So forget about locking them in cold weather.My tailgate door locks work fine ive oiled up the inside mechanism doesn't do much good i don't want power locks so is there anyone that has the same problems as i do and if so is there a fix or better parts.Im not sayin that i actually have things of value in the jeep but it would be nice to be able to lock it.
louielawless is offline
post #2 of 3 Old 05-29-2006, 05:35 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
do you have a hard top if not i wouldnt lock it anyway, then if ppl want in they cut your top and get what they want anyway
RnEmOvr is offline
post #3 of 3 Old 05-29-2006, 05:47 PM
tomkirkland4
tomkirkland4's Avatar
I had the same problem pull the door pannels clean everything with Brakes Parts Cleaner then lube everything up with 3 in one oil spray. Havent had a problem since...
"FREEDOM ISN'T FREE"
For the Rocks: 01 TJ
For the Trail: KFX 400
For the Street: 3.2 Aucra TL
For the Track: Yamaha R1
tomkirkland4 is offline
Do you lock your doors? bikergal Wrangler General Discussion 55 12-16-2009 06:00 PM
can't lock the doors lax YJ Wrangler Technical Forum 7 06-30-2009 06:21 PM
soft top, lock your doors? liquidforcedude TJ Wrangler Technical Forum 44 11-07-2007 10:28 PM
Full doors, soft top, lock or not lock? YCP4x4 TJ Wrangler Technical Forum 34 04-24-2006 09:26 AM
Tailgate lock same as doors? Jimmylh YJ Wrangler Technical Forum 2 08-04-2003 11:09 PM
