Quantcast Can't locate "Switched" and "unswitched" wire leads behind the glove box on 04 TJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Can't locate "Switched" and "unswitched" wire leads behind the glove box on 04 TJ
Old 04-02-2004, 10:11 PM   #1
Sparty
I'm trying to install a CB in my Jeep, and for the life of me, I can't find the "Switched" and "unswitched" wire leads behind the glove box n(should be marked with a paper tag). I read tons of reviews and want to hook it up this way, but I can't find the wires.
Anyone familiar with this, or have an idea of what's going on?
and I apologize in advance if this is a bonehead oversight and I'm too tired to realize it
thanks
Jeep Pics
www.msu.edu/~kerrrand/Jeep.htm
Sparty is offline   Reply With Quote
Old 04-03-2004, 07:27 AM   #2
quadna71
sorry sparty,
we don't get that lucky anymore. i think that they stopped putting those two wires back behind the glovebox in 2002. my old '00 had them and my girlfriend's '01 has them....but my '03 does not. to be honest with you i think you should run the hot wire all the way into the engine bay and directly to the battery (keeping the fuse inline of course). you'll get the best possible signal. i opted to run my ground out there also and bolted it near the battery. a couple of feet of black wiring loom and some zipties later and you can't see the wires at all good luck
chris
2003 TJ Sport - mine, 2001 TJ SE - hers
2001 XJ Sport - ours, 1987 XJ Chief - ours
2000 TJ Sport - sold, 1993 XJ Sport - totaled
1987 XJ Laredo - sold, 1953 CJ-3B - sold
quadna71 is offline   Reply With Quote
Old 04-03-2004, 09:32 AM   #3
blupupher
I have not found them in my '02, but someone said thet they are there, but are tucked into the larger harness to the left of the fuse box. I have not looked on mine yet, but you may check there.
blupupher is offline   Reply With Quote
Old 04-03-2004, 02:23 PM   #4
Dragonmaster
They told me that on my 02 as well, but after looking and rpobing for a day, I couldn't find them. You can run to the fuse box under the hood if you want switched power, and just use one of the empty slots that will have switched power supplied to it.
2002 Jeep TJ SE 2.5L
Sienna Pearl, dual tops, tan interior, 31x10.5's,
1" Rubi Spring lift (yes it does boost an SE 1", ask me how I know)
Work 2 Live, Live 2 Play, Play = JEEP
Dragonmaster is offline   Reply With Quote
Old 04-03-2004, 02:24 PM   #5
Sparty
thanks for the replies guys....
I actually made it a lot easier on myself and went to the shak and picked up a cigarette lighter adapter that I can plug the wires into. Works great.
shoulda thought of that sooner
Jeep Pics
Glock Forum
