Can't get my drive shaft off of the output shaft, any tips/tricks? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Can't get my drive shaft off of the output shaft, any tips/tricks?
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 07-23-2009, 04:41 PM   #1
Dmcastino
I am trying to get my drive shaft off of the transfer case and it seems to be frozen to the splines of the output shaft. For some reason, my drive shaft didn't have the boot over it and I'm thinking that helped lead to it getting all rusted up and what not and now its not moving at all. I'm hoping someone else has had to deal with this before and has a suggestion for me, so far its gotten liberal amounts of PB Blaster and heat and I've tried to ratchet strap it off as well as hammer on it a little. Thanks in advance!
Dmcastino is offline   Reply With Quote Quick reply to this message
Unread 07-23-2009, 06:29 PM   #2
critterjeep
Bump.....we need some suggestions
2003 Rubicon (shale green/khaki), 33x12.5x15 BFG Mud KM2s on Pro Comp 8179s (Firestone Winterforce on stock Moabs for winter), Bilstein 5100s, 3" AEV (nth) Progessive coils, OME steering stabilizer, 1" M.O.R.E. body lift, JKS adj. track bar in the front, 1" JKS budget motor mount lift, RC quick discos, OR-Fab rear rock crawler bumper with 2" receiver, Rokmen 3/16" steering box skid plate, Rokmen rear frame tie-ins, Teraflex 3/16" heavy-duty oil pan skid plate, Alpine CDE-124SXM CD/sat radio MP3 player, Bestop sliding windows, Bestop Safari Bikini top (green military camo), Mopar "windjammer" rear window, Mopar "duster" tonneau cover with tailgate bar, Rockhard Full roll cage with full padding, KC slimlites long range/off road lights on KC windshield mounts, Tuffy security glove box, Pilot LED tail lights.
critterjeep is offline   Reply With Quote Quick reply to this message
Unread 07-23-2009, 06:30 PM   #3
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I've been scratching my head over this one. DMCastino, are you going to reuse that drivehshaft?
Getting Savvy...
Jerry Bransford is offline   Reply With Quote Quick reply to this message
Unread 07-23-2009, 06:41 PM   #4
critterjeep
Don't plan to. I'm hanging out with him now.
Unread 07-23-2009, 06:59 PM   #5
Jerry Bransford
Administrator
It's probably held on by the vacuum inside the slip joint that is pretty well sealed up by the grease and tight fit of the splines. If he's not going to re-use it, I'd drill a vent hole at the end of the outer slip joint at a point away from the opening and see if that doesn't allow it to be pulled off. I'd drill it far enough towards the rear so you hit the open area behind the t-case output shaft where you won't damage it and air goes into the area with the vacuum.
Getting Savvy...
Unread 07-23-2009, 06:59 PM   #6
Dmcastino
Well that makes me feel better. No we are not going to reuse the drive, so right we are trying to cut along the splines and cut the shaft off that way. If I screw up the output shaft, 472cid has graciously given me his spare output shafts, the only problem is he lives a few hours away. So wish us luck I suppose, I'm watching imped4now play with his new grinder under my Jeep as we speak, (its nice that he has a new tool, it means I don't have to be the one grinding things ).
Unread 07-23-2009, 07:02 PM   #7
Dmcastino
It's probably held on by the vacuum inside the slip joint that is pretty well sealed up by the grease and tight fit of the splines. If he's not going to re-use it, I'd drill a vent hole at the end of the outer slip joint at a point away from the opening and see if that doesn't allow it to be pulled off. I'd drill it far enough towards the rear so you hit the open area behind the t-case output shaft and where you won't damage it.
Good thought! We will do that as well
