Cant get doors off. - JeepForum.com
post #1 of 7 Old 07-12-2010, 03:55 PM Thread Starter
chiefdlane
Cant get doors off.
Just got a 2002 Wrangler (TJ?) and I can not get the doors off. My 86 CJ came right off with a lift of the door. I understand there are supposed to be nuts on the bottom of the pins but I can't find any. I'm about ready to get the sawz all out. Any help would be much appreciated
Thanks
chiefdlane is offline
post #2 of 7 Old 07-12-2010, 04:07 PM
bdmead01
Take the nuts off of the hinges and lift up. The fit may be a little more snug than you are used to w/ a CJ, so working the door back and forth as you lift will help.
bdmead01 is offline
post #3 of 7 Old 07-12-2010, 04:09 PM
wl07
sounds like he doesnt have the nuts on the door pins. i would try to gently hit them up with a hammer to start with to see if they loosen up. The first time i took my doors off it was a little tight but the more you take them off the easier they are to take off.
wl07 is offline
post #4 of 7 Old 07-12-2010, 04:10 PM
cidd
mine was a pain the first time I took them off to just keep at it wiggel and pull up at the same time and sooner or later theyll fly off .
cidd is offline
post #5 of 7 Old 07-12-2010, 04:13 PM
danielbuck
1946 CJ2
the nuts have paint on them, and are kind of rounded off (because of the paint). One on the bottom of each hinge (facing downward). They don't look like nuts because of the paint. If you see threads on the bottom of each hinge, then they are already off, nothing else securing the doors on but friction.
Once you have them off, the door should lift right off. My driver side door came off with the first tug. My passenger side door took a few good pulls (and opening and closing the door a little bit inbetween each pull) to get it off, for some reason it was tighter then the driver side (they've never been pulled off by the previous owner). If yours haven't ever been pulled off, they may be tight too? But the only thing securing it on is the 4 painted nuts (two on each door).
danielbuck is offline
post #6 of 7 Old 07-15-2010, 03:15 PM
bxpig0341
2002 XJ Cherokee
i fired a few rounds of buckshot at mine and they came right off
bxpig0341 is offline
post #7 of 7 Old 07-15-2010, 03:22 PM
jeepinmichguy_
get some muscles.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Originally Posted by JeepForum123 View Post
you all have nice rigs, stop being f****** a**holes.
jeepinmichguy_ is offline
door , door removal , stuck , tj , wrangler
Half doors to full steel doors - '94 body, '88 doors xponce YJ Wrangler Technical Forum 8 02-20-2010 03:29 PM
hard topw fulls doors vs soft top w half doors airdevil85 YJ Wrangler Technical Forum 5 01-13-2010 10:37 AM
Newer TJ Half Steel Doors?....or Bestop 2 Piece Soft Doors sweetguardian00 TJ Wrangler Technical Forum 16 02-14-2008 07:21 PM
Yeah Baby! Tube doors for back doors of 4 door! JLH JK Wrangler Technical Forum 2 06-23-2007 08:27 AM
Buying TJ with hardtop & hard doors, but I want a soft top & half doors xxxxxxxxxxxxxxxxxxxgksspot TJ Wrangler Technical Forum 11 10-26-2003 09:16 AM
