Can't find my rim size... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Can't find my rim size...
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 07-14-2002, 12:45 PM   #1
RobC
Hi guys...
My TJ is running P225/75/15 Goodyears, and as far as the charts (although incomplete) I've read on many tire manu's websites...I think my rims are 8"s which would mean I could probably throw 32" tires on them...I think. That's as big as I want to go...for now.
Does anybody have any way to refernce the rim size without taking the tires off? Owners manual, and all the paperwork I got with my TJ doesn't show me what I've got becauise everything is for the TJ Sport, and my TJ is this newer TJ Apex Special Edition model that has the 225's instead of the 215s on chromed steel wheels instead of the aluminum ones. Daimler Chrysler publishing also tolds me the FSM will be specific to the generic TJ, so certain stuyff on mine probably won't be documented in it...but all the mechanical stuff should/will be the same. God, I hope so...
Thanks!
btw: here she is...er...my fiancee as well!
Cheers!
Salmon - the other pink meat
RobC is offline   Reply With Quote Quick reply to this message
Unread 07-14-2002, 12:53 PM   #2
Bob J
I think the Canyon's are the only stock 8" rim, but I could be comepletly wrong, you could always measure with a ruler
1984 AMC Eagle
2006 TrailBlazer
Sig v.55
Bob J is offline   Reply With Quote Quick reply to this message
Unread 07-14-2002, 01:25 PM   #3
'drack
Rob, those are 15x7's. I personally wouldn't go any wider than 10.50's on the factory 7's, but 32x11.50's are possible. You will have rubbing issues up front during turns and you'll have to keep a vigilant eye on the air pressure to make sure they don't wear funky. If you have 32's in mind, I'd look at upgrading to an 8" wheel. HTH
Keith
[b]'00 TJ with some stuff[/b]
'drack is offline   Reply With Quote Quick reply to this message
Unread 07-14-2002, 01:49 PM   #4
RobC
Thanks for the info....I was afraid of that. Ah well...
Btw...I love your rims, 'drack (no, that's not a come-on!! ). You said those are AC97's or something right? Do they have a Canadian distributor?
Cheersd guys 'n gals...I'm off to do some small-time offroadin' today bbl.
Unread 07-14-2002, 02:21 PM   #5
'drack
Thanks . They're AR767's(mine have 4.75" backspacing, but they're also available in 4"). I'm sure there's a place up your way to get them, but mine cost a hair less than $40 stateside . They're cheap, so if you destroy one, a replacement is only gonna cost two cases of beer .
Keith
