can't find a definitive answer to this question?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > can't find a definitive answer to this question??
1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,Zone Offroad Body and Suspension Lift Kits, Brackets, Disc
Unread 12-14-2005, 11:28 AM   #1
blacktjsport
I remember reading somewhere that heim joints, or other similar joints in the suspension and so forth are not so conducive to mud?? Is this assumption right. I am looking to upgrade lots of the suspension and steering components in the near future, however much of my wheeling often consists of mud holes as well as rocky trail sections. What should I go with?? Any suggestions?
thanks in advance,
--Matt
~~2000 Black TJ Sport~~
-Parts list keeps growing...
blacktjsport is offline   Reply With Quote Quick reply to this message
Unread 12-14-2005, 11:33 AM   #2
Texas TJ
Hiem joints are fine as long as you keep them VERY well greased (like tahe a grease gun with you) because they are not sealed. they will squeak and grind and wear out pretty quick.
for like control arms you could use the currie johnny joints they are sealed better. but they can get expensive
heres the link
2001 TJ YELLOW
[COLOR="Yellow"][SIZE="4"]I flopped and broke my piece[/SIZE][/COLOR]
If it won't budge, get a bigger hammer, if it breaks in the process it needed to be fixed anyway.
Texas TJ is offline   Reply With Quote Quick reply to this message
Unread 12-14-2005, 11:40 AM   #3
blacktjsport
Yea I have looked into the Johnnie joints but they are so expensive!! I am kinda torn here b/c the stock joints and bushings have served me so well for many miles I hate to take them off and put something completely different in and not have it perform as well. I guess that's why I asked the question and I hope that some more experience guys who run the same terrain as I will chime in with what they are running and what works for them. I should also stress that this Jeep is and will be my daily driver for a LONG time. Thanks again,
--Matt
Unread 12-14-2005, 11:45 AM   #4
BigJeepJay
Up here in NE it seems like I have to change Heim joints every 6 months or so even with lubeing. I just recentley switched over to Johnnie Joints and so far they pretty awesome and very cheap to rebuild if you need to.
Pics...
[URL="http://smg.photobucket.com/albums/v516/JeepJay/"]http://smg.photobucket.com/albums/v516/JeepJay/[/URL]
TJ Stretch Thread...
[URL="http://www.jeepforum.com/forum/showthread.php?t=348220&page=3"]http://www.jeepforum.com/forum/showthread.php?t=348220&page=3[/URL]
BigJeepJay is offline   Reply With Quote Quick reply to this message
Unread 12-14-2005, 12:51 PM   #5
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Heim joints are not the correct choice for a rig that is driven regularly. They just plain wear too fast for that kind of use and they're not easily greasable since most don't have grease zerks. This is why you never see factory installed heim joints on suspension components.
Getting Savvy...
Jerry Bransford is online now   Reply With Quote Quick reply to this message
