Can't fill my fuel tank - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Can't fill my fuel tank
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO TeraFlex JK 2/4 Door 2.5" Lift Kit!! DEALS AT ROCKRID
Unread 03-08-2007, 04:22 PM   #1
winlit
I had my fuel pump replaced by a machanic. They had to drop the gas tank to replace the pump. Since the replacement I can only pump a little over 1/2 tank before before the gas pump shuts off. I can continue to pump but it only a little at a time until I fill the tank 10 minutes later. What up with that? Did the mechanic mess something up. I have my doubts about the mechanic as he diagonosed that I needed a full pump when all I needed was a crackcase sensor.
Thanks for any help.
1997SE Jeep Wrangler
winlit is offline   Reply With Quote Quick reply to this message
Unread 03-08-2007, 05:26 PM   #2
redluve1
maybe the breather tube is messed up?
6/5/2011 back in a jeep. 4 door jeep wrangler, green,hard top, 6 speed transmission!
redluve1 is offline   Reply With Quote Quick reply to this message
Unread 03-08-2007, 07:00 PM   #3
edzakory
I just replaced my entire fuel pump assembly and have the same symptoms.
I know the sender in the fuel tank is not reading the level correctly because I measured the amount of gas poured into the tank when completly empty. I used a Carter OEM replacement and as others will tesify, most fuel gauges do not give an accurate reading.
The problem with complete filling may be due to the breather tube or the anit-syphon valve. The air has to be replaced by fuel and rapid filling causes the fuel to slosh back up the fill hose. This cuts off the fuel flow from the pump unless you fill really slow.
Unless I plan on a trip to Hole in the Rock, UT, spending the time to completly fill the tank is usually not necessary.
edzakory is offline   Reply With Quote Quick reply to this message
Unread 03-08-2007, 07:02 PM   #4
UTmike
Mine does that to me occassionaly. If I pull the gas nozzle out a half inch or so, it lets me fill the rest of the way up.
4.5" RE SF Lift, 1" BL, 35" Cooper Discoverer STT, Lockrite Locker, 8.8 Rear, AA SYE, Tom Woods DS, Sliders, Skids, Bumpers, Rear Stinger, RockCrusher Diff Covers, 8000# Winch, Herc'd Tub, Homemade Deck Cover, On Board Misting System and Faucet
UTmike is offline   Reply With Quote Quick reply to this message
Unread 03-08-2007, 07:12 PM   #5
conor.davis
mine does that to me all the time i just have to tilt the gas pump handle counter clockwise a quarter turn...
2001 Wrangler Sport 4.0, 5-speed, 4.11's, detroit trutrack (front), aussie locker (rear), 4.5'' Rubicon Express, K and N cold air intake, Flowmaster 40 series muffler, 33" BF Goodwrench Mud Terrain, Warn 8,000lb Winch, 6" extended fender flares, Bestop oversize tire carrier, Explorer Pro Comp off road lights.
conor.davis is offline   Reply With Quote Quick reply to this message
Unread 03-08-2007, 09:42 PM   #6
Daniel TJ
Same thing with mine...
Daniel TJ is offline   Reply With Quote Quick reply to this message
Unread 03-08-2007, 09:49 PM   #7
PGCI
2009 JK Wrangler
Probably breather problems, but mabye too harsh of an angle on the hose from the filler neck to the tank?
2009 Black Rubicon Unlimited, RR XHD front stubby, Ramsey 8,000lb. winch, Husky Floor Liners, Cobra CB, 5' Firestick Antenna.
2007 Rock Red XK
PGCI is offline   Reply With Quote Quick reply to this message
Unread 03-09-2007, 08:27 AM   #8
trekkindave
I know this sounds stupid.. but did you try another gas station? I've had this problem on a couple cars that never had any work on them. Sometimes its just he way the pump goes into the filler hole... Thats my 2 cents
_________________________
[COLOR="Blue"]Member #320 Blue Jeep Club[/COLOR]
2007 Wrangler Unlimited Steel Blue
Too Stock (FOR NOW)
trekkindave is offline   Reply With Quote Quick reply to this message
