Cant engage clutch when engine is on - JeepForum.com
post #1 of 5 Old 08-24-2010, 11:09 PM Thread Starter
FarouT
I have a 98 wrangler 4.0l 5 speed(AX15).
I just replaced the clutch and right before and now i cannot put it into gear when engine is running. I can put it into gear when engine is off then turn it on, go all the way to fifth then back down to third but thats it. and i have to turn it off again to go into reverse......
I have a new slave cylinder in it that was replaced about 2 months ago.
the reason i put a new clutch in is because the pilot bearing burned up.
I am at a total lost of why it is acting like this.
does anybody have any ideas?
FarouT is offline
post #2 of 5 Old 08-24-2010, 11:14 PM
wrangler1977
It could be that you have air in the hydraulic line that needs to be bled off. Air compresses so there is nothing to push the slave sense the air smushes in the line. If this is not it then it is always possible that the slave cyl. is bad, even though it is newer. Either way it sounds like the clutch is not disengaging.
wrangler1977 is offline
post #3 of 5 Old 08-24-2010, 11:25 PM Thread Starter
FarouT
im leaning toward bad slave. i bled the crap out of it.
FarouT is offline
post #4 of 5 Old 08-28-2010, 02:06 AM Thread Starter
FarouT
i figured it out...
after doing a ton of research i found out that when i put it all back together i didnt pay enough attention to the clutch fork. although it looks the same, i install it wrong. the slots for the throw out bearing are suppose to be on the pivot ball side.
FarouT is offline
post #5 of 5 Old 08-28-2010, 02:30 AM
Kiwi_TJ
I had the same symptom when the springs holding the throwout bearing onto the clutch fork broke so that the bearing rotated into the gap on the clutch fork.
1997 TJ Soft Top/ Half Doors
4.0 I6 with 5 Speed Manual | K&N Panel Filter | D30/D44 | 3.07 Gears | Banks Torque Tube Header
31*10.5 R15 Maxxis Trepador Radial Tyres | 2" BDS Spring Lift | Bilstein 5100 Shocks | JKS Discos | JKS Rear Swaybar Links | 100W Narva Spotlights
Kiwi_TJ is offline
clutch , engage , engine , running , on , tj , wrangler
Clutch Pedal soft, no resistance, does not engage clutch. Shivam YJ Wrangler Technical Forum 25 02-20-2017 04:10 PM
92 YJ Clutch Doesn't Engage soundline YJ Wrangler Technical Forum 6 06-24-2010 10:20 PM
clutch wont engage when engine warms up rkn4569 TJ Wrangler Technical Forum 3 04-10-2010 07:27 AM
Clutch will not engage lonestar_yj YJ Wrangler Technical Forum 3 11-26-2008 04:05 PM
Cannot engage clutch... jarods7920 TJ Wrangler Technical Forum 2 11-22-2008 07:32 PM
