Can't change heat/ac temperature - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Can't change heat/ac temperature
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 07-23-2010, 09:08 AM   #1
ohfourtj
Just did a search and couldn't find anything relating to this problem.
About a year ago I had to replace the switch that controls the speeds for the heat/ac and it fixed my one speed issue. A month or two later I lost the ability to change the temperature of the air flowing out. Is there a replacement part for this and how would I go about fixing it? Is it possible that the hot/cold knob is not engaging properly or is there a thermostat behind it? Any help would be greatly appreciated.
It is a 2004 TJ Sport 6 cyl. with 40,000 miles.
Thanks
-Chris
ohfourtj is offline   Reply With Quote Quick reply to this message
Unread 07-23-2010, 09:14 AM   #2
TheBoogieman
Evil Inside.
TheBoogieman's Avatar
Pull the knob off and check it for cracks.Mine did the same thing and the knob itself was broken.
TheBoogieman is offline   Reply With Quote Quick reply to this message
Unread 07-23-2010, 12:03 PM   #3
bigchevyman24
Look under the dash below the glovebox. There should be a cable that runs from behind the a/c control that moves a little lever down there side to side. At least that's how the earlier TJ's are. The cable may have come off or broke. That happened to my old 97...
CURRENT: 2001 WJ V8 LIMITED - Quadratrac, 60th anniversary, Fat Bob's 2.5/2 lift, HID's, roof rack, 31" Rugged Terrains, 5k lb Curt Hitch
SOLD: 2000 WJ 2WD CONVERTED TO 4X4, 97 TJ ON 35'S, 95 XJ ON 33'S
bigchevyman24 is offline   Reply With Quote Quick reply to this message
Unread 07-23-2010, 12:37 PM   #4
LandoCommando
The blend door might be busted.
Try a search on that.
Signatures are for attention whores.
Oh the irony.
LandoCommando is offline   Reply With Quote Quick reply to this message
Unread 07-24-2010, 09:28 PM   #5
ohfourtj
Thanks for the suggestions guys. So far I know the knobs are in good shape and will try out the other two suggestions tomorrow.
-Chris
Unread 07-24-2010, 09:58 PM   #6
TinkerAB
my hot and cold adjustment has never worked i have to reach under the passenger dash and pull the cable by hand.
97 TJ Locked Front and Rear on 35's
TinkerAB is offline   Reply With Quote Quick reply to this message
Unread 07-24-2010, 10:52 PM   #7
LandoCommando
In older TJs like ours the actuator is very much mechanical.
Our temp sliders have a cable that go directly to the blend door.
In newer TJ models it is a knob and an electrical connection that operates a motor on the door.
Oh the irony.
Unread 08-12-2015, 11:56 AM   #8
crobarcapn
In that case is there a way to test if the problem is the knob vs. the electrical connection vs. the motor to the blend door?
crobarcapn is offline   Reply With Quote Quick reply to this message
Unread 08-12-2015, 02:03 PM   #9
chris142
pull the knob off and turn the shaft with plyers.see if the temp changes. you can also listen with the key on engine off and hear the motor above the passengers feet if you turn the knob
chris142 is offline   Reply With Quote Quick reply to this message
Unread 08-12-2015, 02:08 PM   #10
TheBoogieman
Evil Inside.
Raising the dead after being buried for 5 years.
07-24-2010 11:52 PM
LandoCommando
If you don't like the opinions expressed here,then you really don't want to hear the ones I keep to myself.
tj , wrangler , ac , a/c , temperature , control , broke
