Cannot get brake line disconnected from wheel cylinder...any ideas?! - JeepForum.com
post #1 of 4 Old 07-25-2009, 02:49 PM Thread Starter
dirtslut97
I have a 1997 tj sport with a d44 rear and in order to get an inspection sticker i needed to change the shoes. After getting the drivers side done and ready to go i noticed i had brake fluid leaking out of the wheel cylinder on the passenger side so i made a trip to advance auto and got a new one. Well the problem I am having is not being able to get the brake line disconnected from the old wheel cylinder, i have already soaked it in wd-40 and tried to throw a wrench and vice grips to it and i am getting absolutely nowhere. Does anybody have any ideas on this one? Is it possibly reverse thread? Thanks.
dirtslut97 is offline
post #2 of 4 Old 07-25-2009, 03:03 PM
mudb8
want it rite or rite now?
mudb8's Avatar
it's not reverse thead, use pb blaster, wd-40 is about worthless for that stuff...
you may get to make a trip to the local salvage yard for a new line from the jct to the cylinder, or bend one up yourself from some stock the auto parts store have, vise grips aren't very nice to those things..
the bore can also be cleaned up if it's not pitted, then use the new cup seals from your new cylinder and leave the line on there.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #3 of 4 Old 07-25-2009, 03:10 PM
numchuck
pirate squirrel
numchuck's Avatar
keep soaking it down with PB blaster . . . get yourself a line wrench . . . and keep trying . . . if it won't break loose then spray more blaster and wait some more . . . it may take a day or two; but eventually the lube will work its way into the threads . . . if you just can't wait then try applying a small amount of heat with a torch; but be super careful . . . just be sure to get a line wrench . . . there's a good reason for the invention of this tool
- Chuck -
the "Dude" abides
numchuck is offline
post #4 of 4 Old 07-25-2009, 03:13 PM Thread Starter
dirtslut97
I appreciate the responses..i'm going to get some pb blaster and a line wrench once i finish typing this..thanks..
Looking for ideas on brake line brackets after replacing rear upper control arms Houndmaster1 TJ Wrangler Technical Forum 4 06-07-2009 08:00 PM
ideas please....steel wheel rusted onto brake drum Simian Major YJ Wrangler Technical Forum 20 08-06-2007 11:27 PM
replaced brake wheel cylinder - turn light off? dankeenan YJ Wrangler Technical Forum 3 06-04-2007 04:55 PM
Replacing Wheel/Brake cylinder D44? SublimeJeep TJ Wrangler Technical Forum 2 12-28-2003 12:23 PM
Disconnected Swaybars & Brake Line Length Matt Graham TJ Wrangler Technical Forum 1 03-04-2002 07:11 AM
