Can you push start / bump start a TJ? (posts from Boonie Mechanic tricks thread) - JeepForum.com
post #1 of 163 Old 01-27-2011, 08:37 AM Thread Starter
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
In an effort to keep the Boonie Mechanic tricks thread on topic, all posts related to push starting / bump starting / pop starting will be moved here.
Wheelin98TJ is offline
post #2 of 163 Old 01-27-2011, 06:48 PM
EricsGreen98Tj
carry a 2' to 3' of chain(small link) and a few 3" or 4" bolts that has threads all the way up and will fit through the links of the chain. Have 2 nuts for said bolts as well as different width washers. Loop the chain around whatever you are trying to keep in place put the bolt through the chain as close together as possible. use the washers and nut(s) to tighten the chain. It will take the slack out acting kinda like a turnicate. If there is enough chain left you can use it to wrap around something else and tighten it again. I used this a few times on an Isuzu Trooper II to hold the leafsprings in place. It should work to hold a control arm in place as long as you loop it in at least two different directions.
Also cardboard is good to make an emergency gasket.
You can use starting fluid and a flame to set a bead while the tire is still on the rig(just dont use too much!)
JB weld and a pop can work really well to fix a hole in an oil or transmission pan. Cut the pop can in sheets and layer it for best results. Start with a small circle and progressively get larger. Seal with JB every "layer". Another Isuzu Tip.
If the battery is dead, drive a stick so you can drift start it i HATE autos for this reason! Dam slip-0-matics!
I'll think of some more in a little bit.(Im burnt-out)
Building my junk with more junk, so Im always on the look out for more junk....Free to cheap preferably. :D
My junk http://www.jeepforum.com/forum/f22/survivor-project-driveway-frame-swap-33s-build-1280626/index3.html
EricsGreen98Tj is offline
post #3 of 163 Old 01-27-2011, 06:51 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
You can't push start a TJ with a dead battery, no matter what transmission it has...
Knuckelhead is offline
post #4 of 163 Old 01-27-2011, 06:53 PM
EricsGreen98Tj
Why not? I could in my Yj...
post #5 of 163 Old 01-27-2011, 06:56 PM
Knuckelhead
AFSOC Retired
Dead battery = no exciter voltage for the alternator...
post #6 of 163 Old 01-27-2011, 06:57 PM
TheStigX
When you have a dying or dead battery in a TJ, a whole bunch of stuff starts acting crazy. You really need 12V or close to it.
It didn't seem that deep...
TheStigX is offline
post #7 of 163 Old 01-27-2011, 06:58 PM
BigD97TJ
I think he means too dead to start over the engine but not dead enough to power the coil. Like the ticking you get from the starter.
BigD97TJ is offline
post #8 of 163 Old 01-27-2011, 07:08 PM
EricsGreen98Tj
So i cant go outside right now, unhook my battery and drift my tj down the driveway pop the clutch and drive away?
post #9 of 163 Old 01-27-2011, 07:09 PM
Yury
I've done it.......a couple of times.
An Ajax and water paste on a tors bit helps not to strip the stubborn bolts while taking them out.
Home is where the couch is......
Yury is offline
post #10 of 163 Old 01-27-2011, 07:13 PM
rdtj
Yes you can i did it just last week!!!!
rdtj is offline
post #11 of 163 Old 01-27-2011, 07:21 PM
Knuckelhead
AFSOC Retired
Nope.
No you haven't.
Nope.
No voltage to the PCM also means no fuel control...
post #12 of 163 Old 01-27-2011, 07:23 PM
Yury
Nope.
No you haven't.
Nope.
Come on over we will do it together
Yury is offline
post #13 of 163 Old 01-27-2011, 07:27 PM
Knuckelhead
AFSOC Retired
Don't need to, push it till your hearts content.
It won't start with a dead battery...
post #14 of 163 Old 01-27-2011, 07:30 PM
EricsGreen98Tj
So who makes a self exciting alternator? Is there a salvage swap i can do that is self exciting with more amps?
post #15 of 163 Old 01-27-2011, 07:32 PM
EricsGreen98Tj
I've drift started many vehicles with fuel injection. When the batteries were so low that they would only click-click the starter and not turn over the alt.
Boonie Mechanic tricks five-0 TJ Wrangler Technical Forum 174 08-01-2012 07:02 PM
push button start Brown6041 YJ Wrangler Technical Forum 6 10-18-2009 03:12 PM
Push start? petrus JK Wrangler Technical Forum 0 04-20-2008 08:30 AM
Push start a TJ jzmtl TJ Wrangler Technical Forum 21 09-12-2006 04:45 PM
Push Button Start truckie453 TJ Wrangler Technical Forum 7 10-13-2004 05:52 PM
