Can you look at this video of my fan clutch? - Page 2 - JeepForum.com
post #16 of 22 Old 07-12-2010, 12:22 PM
TJ311
This is pretty much why I hate fan clutches. When I start my Jeep cold, I hear the fan spinning up for a bit and then slowing down several times within the first 5 minutes of running. You can spin it by hand when cold/not running with a little resistance, but how do you really know if it's bad or not. If it is supposed to lock up as temperature rises, why does it spin up when cold? I'll be moving to an electric soon.
TJ311 is offline
post #17 of 22 Old 07-12-2010, 01:13 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Because the viscous fluid has to run back into its reservoir when the fan clutch is cold.
I would think twice (and read more) about running an electric fan...
Knuckelhead is offline
post #18 of 22 Old 07-12-2010, 01:16 PM
TJ311
Think twice about what?
TJ311 is offline
post #19 of 22 Old 07-12-2010, 01:38 PM
Knuckelhead
AFSOC Retired
Installing something that is less efficient/reliable than the OEM setup...IMO
post #20 of 22 Old 07-12-2010, 02:18 PM
TJ311
Seriously? I guess it's good you added "IMO" because "my opinion" would definitely differ.
TJ311 is offline
post #21 of 22 Old 07-12-2010, 02:59 PM Thread Starter
Davids29
There are 8 million other thread that you can argue about electric vs clutch driven fan setups. This thread is about what a good fan clutch looks like. Let's keep it that way.
Davids29 is offline
post #22 of 22 Old 07-12-2010, 04:17 PM
cj847
Based on that limited video, I'd say your clutch is fine.
I am not a fan (haha no pun intended) of any spin test for a fan clutch. The fluid moves between chambers, so unless you know exactly what state it was in when it was shut off, there is no way to guess what it is going to feel like 10 hours later.
If your fan doesn't "roar" 100% of the time, then it is not locked up....and it is obvious that it is not too loose. Hence, it's probably not broken.
97 TJ Sport OPJ project (other peoples junk) I can't remember the last time I bought a new part.
cj847 is offline
Fan clutch , video , working
Loud Clutch Clunk Noise When Engaged/Disengaged Under Load (Video) 01TJfuntime TJ Wrangler Technical Forum 14 10-21-2010 11:59 PM
Clutch Sound.. Throwout Bearing? (video) JeepMongerer TJ Wrangler Technical Forum 6 07-07-2010 09:26 PM
clutch pedal making crackin noise *video* mike68 TJ Wrangler Technical Forum 17 10-01-2008 05:41 PM
Rumble when I idle in neutral with the clutch out? (Video.) TheMightyGoat TJ Wrangler Technical Forum 7 09-25-2007 08:54 AM
Startup noise (apparently not the fan clutch...) with video! GringoLoco TJ Wrangler Technical Forum 12 04-08-2007 09:42 AM
