Can you look at this video of my fan clutch? - JeepForum.com
post #1 of 22 Old 07-11-2010, 07:17 PM Thread Starter
Davids29
Fan test on Flickr - Photo Sharing!
I'm trying to find out if my fan clutch is working right. Everyone talks about if it freewheels, but mine is pretty tight. This video was taken after the jeep sat all night, about 10 hours without running, so it was completely cool. Does it look too tight? Can someone else take a video of their fan clutch that they know is good and working correctly?
Davids29 is offline
post #2 of 22 Old 07-11-2010, 07:21 PM
Weeeee
You need a new fan clutch.
Weeeee is offline
post #3 of 22 Old 07-11-2010, 07:28 PM
TeeJay00
Yup mine does the same... What does that mean???
TeeJay00 is offline
post #4 of 22 Old 07-11-2010, 07:34 PM
Weeeee
Does it sound really loud all the time like the fan is running on high?
It's a viscous clutch and changes speed based on temp. If it is always running loudly then you need a new fan clutch.
Weeeee is offline
post #5 of 22 Old 07-11-2010, 07:40 PM Thread Starter
Davids29
Well, mine has sounded the same since I bought it. I've been trying to solve some bad mileage problems and looking at a lot of things and someone suggested that the fan clutch might be locked up and always robbing power from the motor.
Can someone post a video of a working fan clutch being spun when cold. Maybe someone can post one that has gone completely loose so that there will be something for people to look at in the future when diagnosing fan clutch issues.
Davids29 is offline
post #6 of 22 Old 07-11-2010, 08:06 PM
willydigger
I burned up my fan clutch after trying to go in a pond that was a little too deep.
Start the jeep and let it run. Don't drive it, just let it sit. If the clutch is bad the temp will rise and overheat. Your fluid will boil over.
I managed to get my jeep home from the off-road park (about a 2 hour drive) with no problems. I thought everything was fine until I went to pick up a friend. I had to wait a few minutes for him to come out of his house and that's all it took to over heat.
willydigger is offline
post #7 of 22 Old 07-11-2010, 08:08 PM Thread Starter
Davids29
Mine is the opposite of that. Its too tight, it never disengages.
Davids29 is offline
post #8 of 22 Old 07-11-2010, 08:27 PM
TJdualsport
based off that video?? its not supposed to free spin when its cold. its supposed to have a resistance. looks fine to me. next time after you drive it around, check to see how it spins when the engine is warm (motor off of course)
TJdualsport is offline
post #9 of 22 Old 07-11-2010, 08:48 PM
Dryseals
1980 CJ7
Why do you say that?
Dryseals is offline
post #10 of 22 Old 07-12-2010, 06:06 AM
Weeeee
I went and looked at mine as well and cold it looks like this one as well, I was wrong sorry about that.
Weeeee is offline
post #11 of 22 Old 07-12-2010, 06:15 AM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
your fan clutch is fine. try moving it after the motor has warmed up, motor not running of course. it should then be hard to turn. i think everyone is hearing you let go of the fan, thus making a ringing sound. that is not the fan clutch.
Mail crawling.
MisfitSeven is offline
post #12 of 22 Old 07-12-2010, 09:22 AM
Dryseals
1980 CJ7
We all make mistakes.
Dryseals is offline
post #13 of 22 Old 07-12-2010, 10:43 AM
TeeJay00
Maybe yours doesn't work either
TeeJay00 is offline
post #14 of 22 Old 07-12-2010, 11:13 AM Thread Starter
Davids29
I was under the impression that it should turn between 1/2 and 2 revolutions. Is this not correct?
Davids29 is offline
post #15 of 22 Old 07-12-2010, 11:33 AM
Weeeee
I actually replaced mine last year because it was seized up, it work's great now.
Weeeee is offline
Fan clutch , video , working
Loud Clutch Clunk Noise When Engaged/Disengaged Under Load (Video) 01TJfuntime TJ Wrangler Technical Forum 14 10-21-2010 11:59 PM
Clutch Sound.. Throwout Bearing? (video) JeepMongerer TJ Wrangler Technical Forum 6 07-07-2010 09:26 PM
clutch pedal making crackin noise *video* mike68 TJ Wrangler Technical Forum 17 10-01-2008 05:41 PM
Rumble when I idle in neutral with the clutch out? (Video.) TheMightyGoat TJ Wrangler Technical Forum 7 09-25-2007 08:54 AM
Startup noise (apparently not the fan clutch...) with video! GringoLoco TJ Wrangler Technical Forum 12 04-08-2007 09:42 AM
