Can a XJ lift be used on a tj? - JeepForum.com
post #1 of 5 Old 07-31-2012, 08:42 AM Thread Starter
zachtsouprakos
I found a brand new 3" lift for an XJ but i have a TJ would that parts not fit? thanks jeep-wrangler.jpg
My jeeps the red one on the left.
zachtsouprakos is offline
post #2 of 5 Old 07-31-2012, 08:49 AM
mdm
Farm Wheeler
Have you looked at the springs?
XJ rear has leaf springs. Your TJ has coils.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 5 Old 07-31-2012, 11:46 AM
jeeptinker78
The front suspension components will work, but not the rear.
'97 TJ: DD and Weekend Warrior
'58 CJ-3B: Dauntless V6, NP-435, D-18, D-30 Front and D-44 Rear (5.38:1), Ramsey 8000# PTO Winch
jeeptinker78 is offline
post #4 of 5 Old 07-31-2012, 12:05 PM
billy_butler
you could totally do it, you just have to change your rear suspension to a leaf spring set up, cut majority of the bracketry off of your rear-end and re-weld new spring perches and stuff. i strongly recomend that you just go ahead and stick with the tj bolt on lifts. rough country makes a 4 inch lift for right around 500 bucks you could squeeze 35s under it then but its not recommended...
billy_butler is offline
post #5 of 5 Old 07-31-2012, 12:14 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
Nothing would work properly.XJ has rear leaf springs and 3" front XJ coils would lift it way more than 3" on a TJ.Just buy a Zone 3" lift.
TheBoogieman is offline
jeep , lift advice , tj , wrangler
Newbie Lift ? - Body lift vs. suspension lift yj_ryn TJ Wrangler Technical Forum 25 10-09-2013 08:51 PM
time to lift my 91 yj what is a good cheap lift and what 1" body lift drenter17 YJ Wrangler Technical Forum 34 06-23-2012 03:45 PM
Confused. Why 4" suspension lift plus body lift instead of taller suspension lift? ezgoin TJ Wrangler Technical Forum 34 02-12-2011 07:04 PM
Can I do this? Adding more lift to RC Series II 4" lift. Body lift or coil spacers? gattaca37 TJ Wrangler Technical Forum 20 09-12-2010 09:13 PM
Feel Kinda dumb asking this... Putting my TJ on a Lift (Work Shop Lift) Ludoc TJ Wrangler Technical Forum 7 03-31-2005 11:03 PM
