-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Can a XJ lift be used on a tj? (http://www.jeepforum.com/forum/f9/can-xj-lift-used-tj-1399737/)
zachtsouprakos 07-31-2012 08:42 AM
1 Attachment(s)
I found a brand new 3" lift for an XJ but i have a TJ would that parts not fit? thanks Attachment 443936
My jeeps the red one on the left.
mdm 07-31-2012 08:49 AM
Have you looked at the springs?
XJ rear has leaf springs. Your TJ has coils.
jeeptinker78 07-31-2012 11:46 AM
The front suspension components will work, but not the rear.
billy_butler 07-31-2012 12:05 PM
you could totally do it, you just have to change your rear suspension to a leaf spring set up, cut majority of the bracketry off of your rear-end and re-weld new spring perches and stuff. i strongly recomend that you just go ahead and stick with the tj bolt on lifts. rough country makes a 4 inch lift for right around 500 bucks you could squeeze 35s under it then but its not recommended...
TheBoogieman 07-31-2012 12:14 PM
Nothing would work properly.XJ has rear leaf springs and 3" front XJ coils would lift it way more than 3" on a TJ.Just buy a Zone 3" lift.
The time now is 03:03 AM.
