can u stack poly spacers? - JeepForum.com
post #1 of 14 Old 03-12-2011, 06:17 PM Thread Starter
gwood408
can you stack poly spacers to lift your jeep? I'm getting a 1.5in poly coil spacer kit and shocks. but I'm wondering if i can get go back in a couple months and get more spacers and stack them for a 3in lift?
gwood408 is offline
post #2 of 14 Old 03-12-2011, 06:39 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
you could, but its a terrible idea and will cause all sorts of other problems.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 14 Old 03-12-2011, 07:16 PM
lancetkenyon
This.
Flexes like a boneless hooker on muscle relaxers.
lancetkenyon is offline
post #4 of 14 Old 03-12-2011, 07:25 PM
NickRicci
sounds like a bad idea to me
NickRicci is offline
post #5 of 14 Old 03-12-2011, 07:49 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Bad,bad,bad!
GOLENJEEPTJ is offline
post #6 of 14 Old 03-12-2011, 08:58 PM
TJ0002
Very bad idea, there would only be the little lip on them holding them together. Using just one it sits up in a hole and the bumper stop is in the center to help catch it if it tries to pop out...
TJ0002 is offline
post #7 of 14 Old 03-13-2011, 06:05 PM
gebirgziege
you could stack them. and they wouldnt pop out due to the huge bump stop column through the middle of
them. -(front)
the back, maybe an issue though.
you should just save a little more and just buy the coil springs. do it right, the first time.
44 Ford gpw rblt all original. 06 LJ Rubicon black on black - project.
gebirgziege is offline
post #8 of 14 Old 03-13-2011, 08:36 PM Thread Starter
gwood408
Ok
gwood408 is offline
post #9 of 14 Old 03-13-2011, 08:37 PM Thread Starter
gwood408
Can I put a 4in lift on and then put the spacers on top of that? Or do the sizes cause and issue?
gwood408 is offline
post #10 of 14 Old 03-13-2011, 08:38 PM
Unlimited04
again, you could, but its a horrible idea and will lead to several serious issues.
Useful Write-Ups:
Funny:
post #11 of 14 Old 03-13-2011, 08:40 PM
Moto4x4
I guess not according to unlimited? i thought it would be fine if your 4" was all spring lift
Moto4x4 is offline
post #12 of 14 Old 03-13-2011, 09:10 PM
Unlimited04
nope. springs won't have enough room to compress and you'll get coil bind in both front and rear. you'd need twice as much bumpstop, and that would defeat the purpose of the lift.
Useful Write-Ups:
Funny:
post #13 of 14 Old 05-11-2011, 07:25 PM
musicpuppy
just buy the lift thatwill please your vision.
WOW DEeeeeepoh ok thank you..
musicpuppy is offline
post #14 of 14 Old 05-11-2011, 07:36 PM
joeksjeep
If, IF, you did want a spacer 3in lift, this site called fat bobs garage sells 3in coil spacers....
I wouldnt recommend it, get new springs if ya want 3inches
92 Xj 190,XXX miles needs love, and a TURBO HA!
150RwHp, 186 Lbs torque Rw, and all at 175XXX miles in my Xj
DD 98 wrangler sport 5spd 4.0 106,XXX miles
Chrysler Factory Trained Jeep technician, and A.S.E. Certified Master Tech
joeksjeep is offline
jeep , lift , poly , shocks , stack
Coil Spacers Poly or Steel what's your opinion? 08XUnlimited JK Wrangler Technical Forum 4 08-19-2010 10:07 AM
Poly Coil Spacers Spotszilla TJ Wrangler Technical Forum 10 03-17-2010 10:56 AM
Poly Coil Spring Spacers - Need to buy, need advice CB3 TJ Wrangler Technical Forum 6 01-15-2009 06:38 AM
Can I stack spacers in the front ? Baotchi JK Wrangler Technical Forum 8 08-02-2007 11:48 AM
1 1/4" Poly Spring Spacers Nick B TJ Wrangler Technical Forum 3 12-30-2006 09:14 AM
