Can a TJ owner show me a picture of the inside of their TJ door. - JeepForum.com
post #1 of 14 Old 07-19-2006, 08:32 PM Thread Starter
NEWtoTHEjeepLIF
I need the see the system that rolls up windows. I wanted to take a picture I mine but my camera is busted... so I can't offer it for comparison...
NEWtoTHEjeepLIF is offline
post #2 of 14 Old 07-19-2006, 09:19 PM
LoneJeeper
i wear foil underwear too
LoneJeeper's Avatar
2013 MJ Comanche
i thought i could help you out and post the diagram in the FSM....... but there isn't one that i can find.
sorry.
lj
ಠ_ಠ
LoneJeeper is offline
post #3 of 14 Old 07-19-2006, 09:30 PM Thread Starter
NEWtoTHEjeepLIF
yeah I know it's weird out there... I couldn't find it??? Haynes basicly acted like jeeps don't have windows...
post #4 of 14 Old 07-19-2006, 11:14 PM
Dolfy
Dolfy's Avatar
Does this help ya?
'00 Blue TJ Sport & '08 Red KK Sport (OIIIIO)
Blue Jeep Club member #170
Thought for the day:
Some people are like Slinkies... They don't really have a purpose, but they still bring a huge smile to your face when you push them down a flight of stairs.......
Dolfy is offline
post #5 of 14 Old 07-19-2006, 11:30 PM
silver97tj
silver97tj's Avatar
hi try this one, hope it helps......
cool beat me to it...
probably different year fsms by the look of fig numbers....
1998 Blue TJ, 4 Cyl., Auto (30rh), Hardtop with installed Sunroof, mostly stock.
31x10.5x15 Mud Tires, TJ Rubicon springs, Mopar Deep Trans Pan and Cooler
Army Vet and proud of it! Have you served your country?
Support our Troops!! Thank You!!!
silver97tj is offline
post #6 of 14 Old 07-20-2006, 11:25 AM Thread Starter
NEWtoTHEjeepLIF
I think I might have broken them already.... We'll see.
post #7 of 14 Old 07-20-2006, 11:30 AM
limecoconut
I wish it really slid out that easily...my manual cranks were a PITA to get out and even worse to manipulate a power crank into. The black sealant on the plastic weather guard is awful as well.
limecoconut is offline
post #8 of 14 Old 07-20-2006, 11:48 AM
iridium
iridium's Avatar
Are you converting to power windows? If so could you let us know how it goes I am interested in making my full steel doors power operable but have no idea how difficult it is going to be.
When you were working on your door did you take it completely apart or are you working through the tiny opening?
iridium is offline
post #9 of 14 Old 07-20-2006, 12:08 PM
limecoconut
I switched mine over, it will sound nuts but you will spend 1-2 hours per door. A1 electric is the kit I used and its direct bolt on replacement for the manual cranks. The setup is clean and works perfectly. The only real issue aside from getting the power cranks around the cable guides for the locks was the fusebox. They want you to pull the entire box and flip it over to splice in lines but there just isnt a whole lot of room to work. In addition the wire they marked as a +20amp switched is wrong, I think I wound up using the one next to it which was pink.
post #10 of 14 Old 07-20-2006, 04:32 PM
BlueFlame
BlueFlame's Avatar
I did a universal kit, the kind that goes over the shafts. It was a snap to install the drives. But I redid the switch wiring to make room in them to put the switch boxes over the shafts, that was a real job! But it worked and looks clean.
BlueFlame is offline
post #11 of 14 Old 07-20-2006, 06:49 PM Thread Starter
NEWtoTHEjeepLIF
I have power windows. I want to go back to stock. I hate them with a passion. I liked them for a week but now they are more hassle than they are worth and they make my doors a ***** to take off and put on. All around they add time to my journeys and complication to my jeep. Also they are just another thing that is not in my control and vulnerable to water. NOT for MY jeep.
post #12 of 14 Old 07-20-2006, 07:36 PM
Erik T.
Erik T.'s Avatar
My door handle pops out of the passenger door everytime I slam it or go over a big/lots of bumps.
Not completely, but the rectangle part sticks out and I have to push it back in.
I'm tempted to just JB Weld it back to the door. The handle works fine, just that big rectangle piece is loose.
-Erik.
Hack work? :rofl: You just described half the modified jeeps on this board.
Erik T. is offline
post #13 of 14 Old 07-20-2006, 08:00 PM
kearns
isn't that just a matter of hammering the little wedges behind the handle in farther?
kearns is offline
post #14 of 14 Old 07-25-2006, 09:21 PM
Erik T.
Erik T.'s Avatar
What little wedges?
-Erik.
Erik T. is offline
replaced interior door latch, door does not open from inside now! the_art_of_desi TJ Wrangler Technical Forum 2 02-06-2009 05:32 PM
Loose wire on engine harness Help, picture inside antonio116 TJ Wrangler Technical Forum 4 09-07-2008 09:10 AM
Artistic Picture inside after mudding, and rust question... BrettDez JK Wrangler Technical Forum 6 10-14-2007 06:00 PM
inside door handle wont open door alecmcmahon YJ Wrangler Technical Forum 2 07-30-2006 07:39 PM
I have a hose missing! ...but for what? Picture inside... zpmada YJ Wrangler Technical Forum 8 03-09-2004 06:51 AM
