Can't shift out of park. Electrical issue? - JeepForum.com
post #1 of 1 Old 02-13-2012, 02:07 PM Thread Starter
tpeks40
99 TJ. Auto tranny. I can't seem to be able to shift out of park. I checked the shifter knob. Took off the tee handle and checked the white thing that everyone seems to have replaced with chopsticks, but that's not the problem. So far I've read enough to figure out I can turn the key to the Aux position, and then shift down into neutral, then start it up and shift between gears without any problems. It's when I put the shifter into Park with the engine running, or with the key turned to the On position that the button cannot be pressed in. I've heard of the brake solonoid, and it seems that there's a clicking going on somewhere in the steering column, if that makes any sense. I know that the brake pedal needs to be depressed prior to shifting out of park, and I'm wondering if this sensor has something to do with it. Any advice will be greatly appreciated. Thanks in advance for any ideas how to solve this issue.
tpeks40 is offline
Jeep won't shift out of park? Grandman79 TJ Wrangler Technical Forum 56 08-07-2017 05:28 AM
Difficult to Shift into Park wshockley TJ Wrangler Technical Forum 5 08-08-2013 06:15 AM
32RH shift issue - will not shift into 2nd automatically noise_maker TJ Wrangler Technical Forum 11 09-09-2012 02:37 PM
Auto wont shift out of park, BRAKE TRANSMISSION SHIFT INTERLOCK MECHANISM seems stuck Rivka TJ Wrangler Technical Forum 19 04-22-2012 08:26 PM
Won't shift to park InfantryWS6 TJ Wrangler Technical Forum 13 06-18-2007 06:41 PM
