Can't locate "Switched" and "unswitched" wire leads behind the glove box on 04 TJ - JeepForum.com
post #1 of 5 Old 04-02-2004, 09:11 PM Thread Starter
Sparty
Sparty's Avatar
I'm trying to install a CB in my Jeep, and for the life of me, I can't find the "Switched" and "unswitched" wire leads behind the glove box n(should be marked with a paper tag). I read tons of reviews and want to hook it up this way, but I can't find the wires.
Anyone familiar with this, or have an idea of what's going on?
and I apologize in advance if this is a bonehead oversight and I'm too tired to realize it
thanks
Sparty is offline
post #2 of 5 Old 04-03-2004, 06:27 AM
quadna71
quadna71's Avatar
sorry sparty,
we don't get that lucky anymore. i think that they stopped putting those two wires back behind the glovebox in 2002. my old '00 had them and my girlfriend's '01 has them....but my '03 does not. to be honest with you i think you should run the hot wire all the way into the engine bay and directly to the battery (keeping the fuse inline of course). you'll get the best possible signal. i opted to run my ground out there also and bolted it near the battery. a couple of feet of black wiring loom and some zipties later and you can't see the wires at all good luck
chris
Current - 13 JKU, 01 TJ
Gone - 03 TJ, 01 XJ, 00 TJ, 93 XJ, 87 XJ, 87 XJ, 53 CJ-3B
quadna71 is offline
post #3 of 5 Old 04-03-2004, 08:32 AM
blupupher
blupupher's Avatar
I have not found them in my '02, but someone said thet they are there, but are tucked into the larger harness to the left of the fuse box. I have not looked on mine yet, but you may check there.
blupupher is offline
post #4 of 5 Old 04-03-2004, 01:23 PM
Dragonmaster
Dragonmaster's Avatar
They told me that on my 02 as well, but after looking and rpobing for a day, I couldn't find them. You can run to the fuse box under the hood if you want switched power, and just use one of the empty slots that will have switched power supplied to it.
2002 Jeep TJ SE 2.5L
Sienna Pearl, dual tops, tan interior, 31x10.5's,
1" Rubi Spring lift (yes it does boost an SE 1", ask me how I know)
Work 2 Live, Live 2 Play, Play = JEEP
Dragonmaster is offline
post #5 of 5 Old 04-03-2004, 01:24 PM Thread Starter
Sparty
Sparty's Avatar
thanks for the replies guys....
I actually made it a lot easier on myself and went to the shak and picked up a cigarette lighter adapter that I can plug the wires into. Works great.
shoulda thought of that sooner
Sparty is offline
Dealer says "dirty throttle body" and needs "to flush/clean the injectors"..... WheelinTJ2004 TJ Wrangler Technical Forum 18 05-17-2010 11:54 AM
Switched/Unswitched extra lines behind TJ glove box?? JeepJeep31 TJ Wrangler Technical Forum 8 06-29-2009 12:07 PM
Anyone want a "locked" glove compartment? write-up MC_NickP TJ Wrangler Technical Forum 7 03-06-2009 07:39 AM
mettalic "clank", "pop", "squeak" txpedro TJ Wrangler Technical Forum 2 03-21-2007 05:45 PM
