Can't get into 4L, grinding noise when I attempt to - JeepForum.com
post #1 of 10 Old 12-05-2013, 08:35 AM Thread Starter
lolitsdaelan
I replaced my clutch not to long ago, and noticed that I was unable to get into 4L after doing so. I had Imped help me with the clutch , so I'm feeling confident that nothing was hurt in the process. I mentioned this to him and he figured it was likely the linkage. So I crawled underneath a bit later and found the linkage, loosened it up, got everything to where it needed to be (where I think it needed to be...).
What's happening is as I go from 4H to 4L (position wise on the shifter), nothing happens. If I try to crank back the shifter a little bit, I hear a grinding noise. I tried pushing on the transfer case arm to shift it into 4L manually (can I even do that?). I started it up, put it in first, and had it grind at me again. I go between 2 and 4H without issue.
Is there anything that could of happened during the clutch replacement (doubt it but I'm no Jeep pro)? I should also note that I've tried this at a dead stop as well as rolling ~2-3mph.
Thanks!
Your HDR looks bad, and you should feel bad
lolitsdaelan is offline
post #2 of 10 Old 12-05-2013, 08:47 AM
bfaas
Are you compressing the clutch when you try? Neutral or in gear?
bfaas is offline
post #3 of 10 Old 12-05-2013, 08:56 AM
King_Inky
Thanks!
Pictures would be great, if possible. A video is even better. Check my posts, I had an issue with my linkage popping out, so I have some pictures of what mine looks like and a link to a youtube video of mine shifting. You should be able to transfer gears by hand like you tried doing. Don't forget there's a neutral position as well. IIRC you have to push to the right before you pull back to get into 4L. Regardless, I would also believe this to be a linkage issue, but without some pictures/ a video, it is hard to say.
King_Inky is offline
post #4 of 10 Old 12-05-2013, 09:09 AM
2k2wranglerx
are you sure you don't need to adjust the linkage? if the trans was out that means the linkage was disconnected and like you said loose...
i'd try adjusting the linkage and go from there.
93 yj. 355 chevy, heads, cam, intake, etc. 35's, bumpers, winch, lights, and a killer stereo.
2k2wranglerx is offline
post #5 of 10 Old 12-05-2013, 09:10 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
It doesn't sound like the tcase shifter linkage is adjusted properly so it can pull the tcase fully all the way into 4Lo.
Jerry Bransford is online now
post #6 of 10 Old 12-05-2013, 10:16 AM Thread Starter
lolitsdaelan
I had a feeling my two problems may of been related (for those who saw my post about the loose linkage). I'll probably have to hold off on diagnosing this issue until I can get the linkage tightened up.
post #7 of 10 Old 12-05-2013, 10:21 AM
tators
Its one and the same issue- loose linkage - failure to shift...
tators is offline
post #8 of 10 Old 12-05-2013, 10:27 AM Thread Starter
lolitsdaelan
The reason I thought it was a separate issue was because I could hear a grinding noise, so my assumption was that it was refusing to engage for some reason. Now it's a bit more clear that while I thought I was maxing out the shifter, the loose linkage was likely bending and eating up the pressure I was applying.
Should I be able to shift into 4L without the linkage if I crawl underneath and move it manually? I pushed the lever down as far as I could, started in neutral, tried shifting to first and still had the grinding sound.
post #9 of 10 Old 12-05-2013, 10:30 AM
biffgnar
biffgnar's Avatar
Yes, you should be able to shift manually at the case independent of the linkage. But presumably if you were underneath it the jeep was sitting still. For the 4L shift that will definitely cause grinding. You can usually force it, in particular if you rock the jeep a little, but it really likes to be moving slowly for that shift.
biffgnar is online now
post #10 of 10 Old 12-05-2013, 10:41 AM
freeskier93
Give it another shot adjusting the linkage. Loosen nut, handle needs to be in 4wd low, manually move the transfer case into 4wd low, then tighten the nut. Sometime it can take a couple shots to get it just right.
freeskier93 is online now
