Can't find a replacement lower radiator hose with a spring in it. - Page 2 - JeepForum.com
 1Likes
post #16 of 16 Old 06-19-2017, 11:38 AM
Fargo
Originally Posted by Jerry Bransford View Post
Springs are no longer needed with today's better hose materials. Just get a Gates, Goodyear, etc. and you're good to go. Most of us will also strongly suggest/recommend you stick with a Mopar radiator and not a store-brand.
Thank you Jerry. I've had good luck with Gates in the past. I'll look into them.
I did order the Mopar radiator after some research and personal experience. My previous TJ I used an all steel radiator and it didn't cool as well as the factory setup. A friend of mine tried several all aluminum aftermarket radiators and had major quality issues. He had to return 2 or 3 before he got one that didn't leak. So I'll stick with the Mopar radiator and just get some Gates or Goodyear hoses. Thank you again.
Jerry Bransford likes this.
6spd manual
LJ Owners Group member #110
Fargo is offline
Lower Radiator Hose replacement. Lefty TJ Wrangler Technical Forum 13 06-29-2013 10:18 PM
Spring Inside Lower Radiator Hose mcoh1030 TJ Wrangler Technical Forum 12 07-26-2010 11:48 AM
Lower Radiator Hose Replacement wazilian TJ Wrangler Technical Forum 3 01-11-2010 01:08 AM
Spring in lower radiator hose? gman30 YJ Wrangler Technical Forum 11 07-29-2008 01:58 AM
Lower radiator hose - internal spring needed? redsoxski TJ Wrangler Technical Forum 4 05-29-2008 05:25 PM
