Can't find my rim size... - JeepForum.com
post #1 of 5 Old 07-14-2002, 12:45 PM Thread Starter
RobC
RobC's Avatar
Hi guys...
My TJ is running P225/75/15 Goodyears, and as far as the charts (although incomplete) I've read on many tire manu's websites...I think my rims are 8"s which would mean I could probably throw 32" tires on them...I think. That's as big as I want to go...for now.
Does anybody have any way to refernce the rim size without taking the tires off? Owners manual, and all the paperwork I got with my TJ doesn't show me what I've got becauise everything is for the TJ Sport, and my TJ is this newer TJ Apex Special Edition model that has the 225's instead of the 215s on chromed steel wheels instead of the aluminum ones. Daimler Chrysler publishing also tolds me the FSM will be specific to the generic TJ, so certain stuyff on mine probably won't be documented in it...but all the mechanical stuff should/will be the same. God, I hope so...
Thanks!
btw: here she is...er...my fiancee as well!
Cheers!
Salmon - the other pink meat
RobC is offline
post #2 of 5 Old 07-14-2002, 12:53 PM
Bob J
Bob J's Avatar
1984
I think the Canyon's are the only stock 8" rim, but I could be comepletly wrong, you could always measure with a ruler
1984 AMC Eagle
2006 TrailBlazer
Sig v.55
Bob J is offline
post #3 of 5 Old 07-14-2002, 01:25 PM
'drack
Rob, those are 15x7's. I personally wouldn't go any wider than 10.50's on the factory 7's, but 32x11.50's are possible. You will have rubbing issues up front during turns and you'll have to keep a vigilant eye on the air pressure to make sure they don't wear funky. If you have 32's in mind, I'd look at upgrading to an 8" wheel. HTH
Keith
'00 TJ with some stuff
'drack is offline
post #4 of 5 Old 07-14-2002, 01:49 PM Thread Starter
RobC
RobC's Avatar
Thanks for the info....I was afraid of that. Ah well...
Btw...I love your rims, 'drack (no, that's not a come-on!! ). You said those are AC97's or something right? Do they have a Canadian distributor?
Cheersd guys 'n gals...I'm off to do some small-time offroadin' today bbl.
RobC is offline
post #5 of 5 Old 07-14-2002, 02:21 PM
'drack
Thanks . They're AR767's(mine have 4.75" backspacing, but they're also available in 4"). I'm sure there's a place up your way to get them, but mine cost a hair less than $40 stateside . They're cheap, so if you destroy one, a replacement is only gonna cost two cases of beer .
Keith
'drack is offline
cant find tire size online anymore CreepyCrawler95 YJ Wrangler Technical Forum 12 04-26-2009 09:32 PM
Shock size with 2" shackles... Stock size or longer? Obie95Sahara YJ Wrangler Technical Forum 1 11-12-2008 02:23 PM
wheel center hole size vs hub ring size thartman YJ Wrangler Technical Forum 8 10-27-2008 10:22 PM
TPS or something else, help me find the right size radiator bolt veritas4156 YJ Wrangler Technical Forum 8 01-24-2008 08:29 PM
best way to find out what size lift? AK1904 YJ Wrangler Technical Forum 3 07-31-2003 01:10 AM
