can't find a definitive answer to this question?? - JeepForum.com
post #1 of 5 Old 12-14-2005, 10:28 AM Thread Starter
blacktjsport
I remember reading somewhere that heim joints, or other similar joints in the suspension and so forth are not so conducive to mud?? Is this assumption right. I am looking to upgrade lots of the suspension and steering components in the near future, however much of my wheeling often consists of mud holes as well as rocky trail sections. What should I go with?? Any suggestions?
thanks in advance,
--Matt
~~2000 Black TJ Sport~~
-Parts list keeps growing...
blacktjsport is offline
post #2 of 5 Old 12-14-2005, 10:33 AM
Texas TJ
Texas TJ's Avatar
Hiem joints are fine as long as you keep them VERY well greased (like tahe a grease gun with you) because they are not sealed. they will squeak and grind and wear out pretty quick.
for like control arms you could use the currie johnny joints they are sealed better. but they can get expensive
heres the link
2001 TJ YELLOW
I flopped and broke my piece
If it won't budge, get a bigger hammer, if it breaks in the process it needed to be fixed anyway.
Texas TJ is offline
post #3 of 5 Old 12-14-2005, 10:40 AM Thread Starter
blacktjsport
Yea I have looked into the Johnnie joints but they are so expensive!! I am kinda torn here b/c the stock joints and bushings have served me so well for many miles I hate to take them off and put something completely different in and not have it perform as well. I guess that's why I asked the question and I hope that some more experience guys who run the same terrain as I will chime in with what they are running and what works for them. I should also stress that this Jeep is and will be my daily driver for a LONG time. Thanks again,
--Matt
post #4 of 5 Old 12-14-2005, 10:45 AM
BigJeepJay
BigJeepJay's Avatar
Up here in NE it seems like I have to change Heim joints every 6 months or so even with lubeing. I just recentley switched over to Johnnie Joints and so far they pretty awesome and very cheap to rebuild if you need to.
Pics...
TJ Stretch Thread...
BigJeepJay is offline
post #5 of 5 Old 12-14-2005, 11:51 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Heim joints are not the correct choice for a rig that is driven regularly. They just plain wear too fast for that kind of use and they're not easily greasable since most don't have grease zerks. This is why you never see factory installed heim joints on suspension components.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
Fuel gage ? I did a serch but didn't find the answer. 1trackmind YJ Wrangler Technical Forum 8 01-14-2010 07:36 AM
Question about lift and tires that I cannot find an answer on coachholland YJ Wrangler Technical Forum 7 08-12-2009 04:47 PM
soft top question/ can't find the answer? kiwanoron TJ Wrangler Technical Forum 9 08-11-2009 08:35 AM
Newbie Question - Couldn't find answer Jeep_Maniac TJ Wrangler Technical Forum 26 08-11-2009 06:07 AM
need definitive answer on backspacing derby TJ Wrangler Technical Forum 3 11-20-2002 03:17 PM
