Can't decide which CA's to get? - Page 3 - JeepForum.com
post #31 of 40 Old 07-28-2010, 01:11 AM
asknight
http://www.jeepforum.com/forum/f9/sa...4/index48.html
Post 715 pretty much sums up what you can achieve with Currie Arms and their lift parts.
Much of post 715 can be directly attributed to the shocks. Who makes the shocks used in Currie kits?
asknight is offline
post #32 of 40 Old 07-28-2010, 08:20 AM
-dirt-
Originally Posted by mudb8 View Post
IMO JKS arms are a good choice for a Daily driver that's lazy and doesn't feel the necessity of maintaing bushings with a grease gun...
-dirt- is offline
post #33 of 40 Old 07-28-2010, 08:54 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Much yes, but if you believed the internet BS about clevite bushings, there's no way to make it ride that good with just a shock swap. The fact that I've had 10 different folks drive that rig and all make the same comment that it's the best riding Jeep they ever driven or ridden in, pretty much tosses that myth right in the trash.
If those shocks were the panacea that you're making them out to be, I should be able to put them on any rig regardless of arm and have it ride the same.
I do agree very much that no one aspect will give you the great ride and handling that rig has, but if you believe all the internet BS about factory control arm bushings, then I shouldn't be able to use the Currie arms and get any kind of a decent ride much less a great ride.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #34 of 40 Old 07-28-2010, 05:14 PM
crgrissom
Master of Reality
crgrissom's Avatar
Originally Posted by dirt_j00 View Post
There is one guy on here who has run both JKS and Currie, and his insight was helpful. Can't remember his u/n. Maybe he'll post.
I don't know if you're talking about me, but I ran the JKS arms before I got my Currie's, and honestly I could tell no difference in the ride. Don't assume you have to stay away from JJs due to thinking you'll get a harsher ride. Just plain not true.
Chuck
Chuck Grissom
Opportunity is missed by most people because it is dressed in overalls and looks like work.
- Thomas A. Edison
crgrissom is offline
post #35 of 40 Old 07-28-2010, 09:38 PM
-dirt-
Chuck
If I remember right, this person has been through Moab a couple time on both sets of control arms. That you? I thought he was from the West Coast.
-dirt- is offline
post #36 of 40 Old 07-28-2010, 11:25 PM
asknight
Don't get me wrong, I'm no fan of the factory bushings. I've ridden in plenty of Jeeps with various aftermarket CAs that ride much better than mine on stock CAs. My disdain for the stockers remains even without mentioning the amount of visible slack in my CA bushings with only 22k easy miles on them.
I never knew beforehand that to setup a TJ properly with a 2 1/2" lift and off road tires would require trackbars, swaybars, links, bumpstops, tie rods, upper control arms, lower control arms, slip yoke eliminators, new driveshafts, lockers, gears, steering box upgrades, motor mount lifts, a second mortgage, a divorce, and a third job.
I now know.
asknight is offline
post #37 of 40 Old 07-28-2010, 11:41 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I now know.
If you ever get the opportunity to chat with a Jeep engineer sometime, take advantage and do so.
During one of those chats I learned that they have a test where they accelerate from a dead stop to about 30 miles an hour, stop as fast as possible, and then do it again repeatedly for 2 weeks.
Halfway through they have to pull it into the shop and replace all the control arms because the bushings are shot. This is with new test mules.
I am Savvy
mrblaine is offline
post #38 of 40 Old 07-29-2010, 05:52 AM
crgrissom
Master of Reality
crgrissom's Avatar
Not me, but I wish...
Chuck Grissom
- Thomas A. Edison
post #39 of 40 Old 07-29-2010, 09:19 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Was it someone with a username like daveshan from Co?
I am Savvy
mrblaine is offline
post #40 of 40 Old 07-29-2010, 10:21 AM
-dirt-
Found it:http://www.jeepforum.com/forum/f9/jk...ml#post9413921
-dirt- is offline
control arm
Difference between first and second gen RE CA's? subzeroedj TJ Wrangler Technical Forum 8 09-20-2009 09:37 PM
SYE and adjustable CA's jchappy TJ Wrangler Technical Forum 15 01-08-2009 12:19 PM
Noisy RE Adj CA's? mkuzmukerau TJ Wrangler Technical Forum 5 07-11-2005 02:31 PM
Measuring CA's JakeJones TJ Wrangler Technical Forum 3 12-26-2004 01:19 AM
Best vibe fix: adj. CA's or SYE? SmithersGS TJ Wrangler Technical Forum 2 10-30-2004 06:34 AM
