Can it Really be a Bent Front Axle Housing? - JeepForum.com
post #1 of 6 Old 09-27-2011, 09:03 PM Thread Starter
1badxj
So the other day, when I went to get my new MTR's mounted and an alignment done (I have lifetime free at Firestone) after I added 1" spacers, the tech told me I most likely have a bent housing due to the camber being off by -1.3* passenger and -.96* driver's. Making the tops of the tires viewed straight on like this: / \
I've been researching this for the last few days, and I think they didn't check everything out as they should. When I bought it last year, the tires had over 30k mi. and no abnormal wear. I had an alignment check at the same place a year ago when I got some replacement 265's and checked out fine then. I have babied it the few times I wheeled it, never was never in a crash or jumped it. They swear they checked ball joints, but I'm thinking that's the problem.
So, how can I get it checked for trueness? Or, should I just go ahead and get the ball joints and see how it is 1st before proceeding?
2005 Rubihara #111 of 1000 (for sale:
1badxj is offline
post #2 of 6 Old 09-27-2011, 09:05 PM
dwbarger
do the balls first and see if that takes care of it. it is possible yes but i have heard of axles coming from the factory worse than this.
dwbarger is offline
post #3 of 6 Old 09-27-2011, 09:07 PM
footypaul
Get a straight edge and check it
footypaul is offline
post #4 of 6 Old 09-27-2011, 09:15 PM Thread Starter
1badxj
I've done this already with a 2ft metal carpenter's square.......... and from housing to knuckles, there's no noticeable bends that I can tell.
1badxj is offline
post #5 of 6 Old 09-27-2011, 09:19 PM
firejeep42
Could be the wheel bearings also, check for play in the ball joints and wheel bearing
~Dave~
firejeep42 is offline
post #6 of 6 Old 09-27-2011, 11:34 PM Thread Starter
1badxj
Good idea, and for some reason, one I didn't think about.......I'll personally put stands under the axle, taking the weight off these components, and see if there's any play in the ball joints and uni-bearing/hubs.
1badxj is offline
How to check if an axle housing is bent? Erik T. TJ Wrangler Technical Forum 12 09-06-2011 08:21 PM
Help wanted with bent axle housing (AUSTRALIA) dragonman TJ Wrangler Technical Forum 4 01-23-2011 05:05 PM
Bent D44 Front Axle housing taftech TJ Wrangler Technical Forum 9 02-09-2010 11:53 AM
Bent Rubicon Axle Housing 514rem TJ Wrangler Technical Forum 3 03-16-2008 08:54 PM
Bent D30 Axle Housing...anyone else? Scafone TJ Wrangler Technical Forum 8 07-04-2006 08:31 PM
