Can a low or dying battery cause a low idle? - JeepForum.com
post #1 of 26 Old 07-25-2010, 07:41 PM Thread Starter
tjdriver
can a low battery or dieing battery make your vehicle idle low?
i'll explain if needed.
tjdriver is offline
post #2 of 26 Old 07-25-2010, 07:45 PM
1jack5
1jack5 is offline
post #3 of 26 Old 07-25-2010, 07:48 PM
kuebelwagen
I say yes. last week My bat went bad, rough idle, died at traffic lights, low cranking power. Put new batt in, problem fixxed!
In love with, Suki.
Pain is weakness leaving the body.
2004 Rubicon
1995 Cherokee
kuebelwagen is offline
post #4 of 26 Old 07-25-2010, 07:50 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Yes, the computer doesn't like low voltage and will lose idle settings.
xjfever is offline
post #5 of 26 Old 07-26-2010, 09:56 AM Thread Starter
tjdriver
Originally Posted by 1jack5 View Post
tjdriver is offline
post #6 of 26 Old 07-26-2010, 09:58 AM Thread Starter
tjdriver
it runs fine above idle, but idle is at 200 rpms and when i rev it up and let off it idles down to nothing and dies out. that leads me to believe that the alt is putting plenty of juice for everything and making up for crappy bat.
tjdriver is offline
post #7 of 26 Old 07-26-2010, 10:00 AM
skip11and1
2013 MK Patriot
it might be ur alternator not ur battery. My mustang was doing the same thing so I got a alternator test and the diodes were stuck open on the alternator draining the battery when the car was off.
2013 Jeep Patriot 4x4 FD1 5spd
2004 R6 lowered, stretched, full exhaust, HIDs etc
2004 TJ Columbia package long armed w/ 33's (Sold)
2005 WK, v6 QT1 (girlfriends)
skip11and1 is offline
post #8 of 26 Old 07-26-2010, 10:04 AM Thread Starter
tjdriver
good idea, but i don't think that's it. it's not really really sluggish on start up. just enough to notice. if the alt was bad wouldn't all the electrical not work well while driving it? i'm gonna check the voltage on the bat and see what's up.
tjdriver is offline
post #9 of 26 Old 07-26-2010, 10:08 AM
TJdualsport
if its stalling all the time at lights. try turning your ac on. it usually bumps the idle rpms a little bit. It has helped me in the past when i had a dieing battery.
TJdualsport is offline
post #10 of 26 Old 07-26-2010, 10:22 AM Thread Starter
tjdriver
it doesn't help. it will still idle real low and the compressor kicks on/off very fast.
tjdriver is offline
post #11 of 26 Old 07-26-2010, 10:24 AM
LandoCommando
Bring it down to autozone or advance and get your battery and alternator tested.
Signatures are for attention whores.
Oh the irony.
LandoCommando is offline
post #12 of 26 Old 07-26-2010, 10:34 AM
skip11and1
2013 MK Patriot
the alternator may still be working properly, just when you shut your jeep off it may drain your battery just enough. my mustang started up every time. sometimes hard sometime not. but it idled low and even lower with the a/c on. like landocomando said just bring it to one of the parts stores for a free test.
post #13 of 26 Old 07-26-2010, 10:36 AM Thread Starter
tjdriver
o i c
tjdriver is offline
post #14 of 26 Old 07-26-2010, 10:36 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
When the battery is low enough, the engine will barely idle and it can even stall. Have the battery load tested. The alternator depends on the battery to put out power so if the battery is dead or near dead, the alternator will be dead or near dead too.
Getting
Jerry Bransford is online now
post #15 of 26 Old 07-26-2010, 11:51 AM Thread Starter
tjdriver
thx jerr.
tjdriver is offline
battery , low battery , idle
Battery is dying on me :( alaskanthunder JK Wrangler Technical Forum 14 03-30-2010 03:09 AM
Jeep battery dying scdiver TJ Wrangler Technical Forum 12 01-07-2010 06:28 PM
Battery Keeps Dying TheDiabetic TJ Wrangler Technical Forum 2 09-04-2007 07:12 AM
Battery Dying antics120 TJ Wrangler Technical Forum 3 06-09-2007 07:20 PM
Help with a dying battery, please dodgetk81 TJ Wrangler Technical Forum 13 01-14-2007 08:54 PM
