Can I use 02 TJ Mirrors on an 04 TJ or possibly change them? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Can I use 02 TJ Mirrors on an 04 TJ or possibly change them?
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueTJ 5.25" Speaker Adapters - NalinMFGSmittybilt Products at Oconee Off-Road!
Unread 05-27-2014, 07:11 AM   #1
Jester675
Is there a way to either switch, change or just use 97-02 TJ mirrors on a 2004 TJ Wrangler? the stock mirrors are horrible to adjust and do not give me the visual range that my 2000 jeep mirrors did. I am not sure what they changed but they changed something.
Jester675 is offline   Reply With Quote
Unread 05-27-2014, 07:14 AM   #2
apaTJ
When my 99 tj got hit by a tree the sg
apaTJ is offline   Reply With Quote
Unread 05-27-2014, 07:15 AM   #3
catmechanic
Yes, they changed the plastic cover and the mounts, but the bolt pattern is the same. Only issue is if you only change one side then they won't match, but they are a direct swap.
catmechanic is offline   Reply With Quote
Unread 05-27-2014, 07:15 AM   #4
apaTJ
The shop replaced the mirrors with the newer plastic ones. So I'd assume they would fit.
Unread 05-27-2014, 07:22 AM   #5
Jester675
Ok I thought the bolt pattern looked the same but I didn't want to chance it and buy an older set if I couldn't use them. I will be changing both sides since the new ones won't move in and as I can see very well around me I can't see anything that is directly behind me and it makes my blind spot HUGE. next stop new mirror purchase.
Filthy, Dirty Jeep Girl!
04 TJ Willy's
Camo Crawler
