Quantcast Can I swap my A/C control panel from the slider style in 98 to the dials? - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Can I swap my A/C control panel from the slider style in 98 to the dials?
Old 10-30-2008, 02:38 PM   #1
skygod73
I would like to have the position for head and feet together. On my 98 I have the slider levers and I can only have feet and defrost. I have seen some slightly newer years with the same center dash bezel I have, before they switched to the rounded panel around 03 I think. It looks like it should be a direct swap, has anyone done this? Thanks.
98 TJ 4x4, Auto, Hardtop, 3" ZJ lift, 32x11.5 BFG ATs, Pro Comp 15x8 series 97 wheels, Hi-Lift Jack on the front bumper. More to come...
[url]http://community.webshots.com/user/skygod73[/url]
skygod73 is offline   Reply With Quote
Old 10-30-2008, 05:27 PM   #2
Shrek
Is your temp control a cable or vacuum? I have a 97 w/ cable and can't swap the 99 that's all vac. Not sure about the 98. Looks like the fan switch has the same pinout but the temp and position controls are much different. Let me know if you need the 99 control panel. It's for a Jeep w/ air and all vac controlled.
97 TJ 4.0, AX15, E-Fan, 5" Full Traction Long Arm - D44s /4:88s, 36" TSL/SX Swampers on Cragar Bead Locks, Atlas ll, Outback Extreme OnBoard Air, Hand Throttle, Homemade Sliders, Homemade Rear Roll Cage, M.O.R.E. High Clearance Bumpers, Currie Currectlync Steering, Currie Anti rock, Warn 9.5XP, OR Fab Sport Cage Up Front, I've lost control.
Shrek is offline   Reply With Quote
Old 10-30-2008, 05:51 PM   #3
skygod73
My 98 is the same as your 97 with a fan speed dial and to sliding levers (one for position and one temp), I bet it's cable. It sounds like 99 was the year they changed to vac, and I am SOL. BTW, I do have A/C in mine.
Old 10-31-2008, 09:49 AM   #4
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Its not a direct swap.
You have to swap out at least half the heater box so you have to pull the dash.
The dial controls are also problematic. Lots of issues with the resistor, switch, melted wiring, etc.
I'd stick with the slider controls just for their reliability. I too would also prefer the dial controls but not the problems that come with them.
98 TJ
Wheelin98TJ is offline   Reply With Quote
Glock Forum
