Can I swap in a Dana 44HD for my Dana 35? - JeepForum.com
post #1 of 13 Old 04-14-2014, 12:06 AM Thread Starter
aldersonfilm
In a previous post, I determined that I have to replace my rear end as just about all the gears inside are worn.
My current axle is a stock Dana 35 3.73 with track lock. I found an ad for a Dana 44A or 44HD off a WJ. It has calipers, but nothing in the ad about a track lock system. The guy is also selling a locker for it though.
So my question is, would this be a viable option for a replacement? Would it just bolt right in and would the brake lines that feed the drums, also swap over easily to the calipers?
Even if this axle is a viable option, how easy is it to swap a Dana 35 for a Dana 44? Do I need to buy a kit or anything? Sorry for the noob, questions, but I haven't had to deal with drivetrain issues much until now.
aldersonfilm is offline
post #2 of 13 Old 04-14-2014, 12:25 AM
Jonathanjr1
You can but i think you would be better off finding a ford 8.8 out of an explorer. The 44a has some issues and a very small aftermarket. The 8.8 has a pretty large aftermarket you can also find them in any wrecking yard cheap.
Another option you have is to find a d44 from another tj or lj and swap that in. If you dont have much to spend you could always find another d35.
If you get a d44 or d35 from a tj its a direct swap. If its any other axle you need the brackets maybe a drive shaft adapter or new yoke.
Jonathanjr1 is offline
post #3 of 13 Old 04-14-2014, 08:56 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
The D44 HD, more commonly known as the D44a, from a WJ is not a good option.
It is not bolt in.
It has a different bolt pattern (5 on 5) and different width (about 63" WMS-WMS).
As Jonathanjr1 mentioned, the D44a had limited aftermarket support. Only a couple lockers available and they are lunchbox style.
Wheelin98TJ is online now
post #4 of 13 Old 04-14-2014, 09:26 AM
McLovin
that axle sucks, order an 8.8 or a dana 44.
I have 4 new zone hydro shocks for sale...PM for a price.
McLovin is offline
post #5 of 13 Old 04-14-2014, 10:38 AM Thread Starter
aldersonfilm
If I get, let's say an 8.8 limited slip, will the limited slip work? Don't I need the right electrical connection?
post #6 of 13 Old 04-14-2014, 10:53 AM
trickydick
There are no connections for limited slip, its all automatic. I don't know if ford uses clutch packs or the newer gear type of limited slip but neither one require electric, air, or cable.
trickydick is offline
post #7 of 13 Old 04-14-2014, 02:04 PM
Wheelin98TJ
JEEP FREAK
In the Explorer 8.8s that are factory equipped with a limited slip, it will be a clutch-driven limited slip.
Ford does use a Torsen limited slip (gear-driven) in some other 8.8s, but not the Explorer variant.
post #8 of 13 Old 04-14-2014, 02:44 PM
Border Dave
Got Sand?
Border Dave's Avatar
Do you have any further info on this?
Border Dave is offline
post #9 of 13 Old 04-14-2014, 02:46 PM
McLovin
The bronco/f150 8.8's use the torsen I believe
McLovin is offline
post #10 of 13 Old 04-14-2014, 02:49 PM
Wheelin98TJ
JEEP FREAK
When I said "some other 8.8s", I could have more specifically said in the Ranger FX4 Level 2 8.8s.
Here is info from Torsen on this:
Which Torsen is in the Ranger FX4 - Level 2?
The Ranger FX4 Level 2 comes standard equipped with a pre-loaded Torsen T-2. Ranger production units will start with a 9702 serial number. Click on the following hyperlink How do I decipher the Torsen part number? to view an explanation of what information is found in the Torsen part number on a Ranger FX4 differential.
http://www.torsen.com/general/genera... FX4 - Level 2
Maybe some of the Mustang 8.8s use a Torsen diff, but I'm not sure.
post #11 of 13 Old 04-14-2014, 02:57 PM
Border Dave
Got Sand?
Thanks for the info.
post #12 of 13 Old 04-14-2014, 04:40 PM Thread Starter
aldersonfilm
Seems like an 8.8 is likely to have disc brakes. Anybody know the swap procedure there, since I've got drums in the back?
post #13 of 13 Old 04-14-2014, 04:58 PM
biffgnar
biffgnar's Avatar
There isn't much of a procedure. There is no need to change anything else (e.g. proportioning valve, master cylinder, booster, etc.) other than whats at the wheels (i.e. drums to disks). Just get the lines hooked up. Well, you might have to get new parking brake cables.
Romney in 2020!
biffgnar is offline
dana 35 axel swap , dana 44 , drivetrain , rear axle
