can i run 36" iroks - JeepForum.com
post #1 of 16 Old 07-23-2009, 06:47 AM Thread Starter
outlawjosywales
can i run 36" iroks
i have a 2001 sport with 4.5" short arm lift & 1" bl. i do not have tube fenders(yet). my concern is the clearance. will i have enough to clear the 36" iroks without shredding my fender flares? i'm all set on gears/axles etc. the clearance is what i'm wondering.
Go Anywhere.
outlawjosywales is offline
post #2 of 16 Old 07-23-2009, 06:53 AM
NotURMailman
I would think so. It seems to be the common consensus that 4.5" is good for 35s, so the 1" BL should be enough more for 36s. I'm sure you can find someone who has a similiar set up ion JF to answer for sure. Are youn sure you wanna run 36s with 4.56s? Have you upgraded your steering and brakes? You might have already considered all of those things, but I thought it was worth mentioning them.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #3 of 16 Old 07-23-2009, 07:00 AM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
I ran 36 TSLs with that setup. I have a long arm now and tube fenders because my stock fenders were in rough shape.
older pic at tellico.
more recent photo at Harlan
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #4 of 16 Old 07-23-2009, 07:03 AM Thread Starter
outlawjosywales
stock fenders worn out from the 36's?
Go Anywhere.
post #5 of 16 Old 07-23-2009, 07:20 AM
NotURMailman
From the pictuires I'd say they were worn out from the way he wheels it.
post #6 of 16 Old 07-23-2009, 07:20 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
You can for a fistful of dollars.
TheBoogieman is offline
post #7 of 16 Old 07-23-2009, 07:51 AM
03rubiconMG
yes you can, just adjust your bump stops correctly. and you may want to look into getting tube fenders some day.
I have 37s with that lift but i also have tube fenders.
2003 white rubicon on 37s
03rubiconMG is offline
post #8 of 16 Old 07-23-2009, 07:53 AM
diamonddave
2010 JK Wrangler
I run 35"s with 3" inch coils in the front and a budget boost out back !' bl and tube fenders with no prob. just adjust bumpstops if your worried about your fenders
2010 JK, Rescue Green, 6 speed, RC 2.5, 35" km2's,
8k winch. Rugged Ridge stubby, garvin expidition rack.
2003 TJ 3" of lift, 35" BFG KM2"s, Detroit tru tracs front n rear, 4.56's, Rokmen front bumper, rock hard sliders, Gen-Right tube fenders, blahblahblah. (for sale)
diamonddave is offline
post #9 of 16 Old 07-23-2009, 09:14 AM
RYANSTULC
It'll work great.
I run 36" SX's on 3.5" springs,,,and no BL.
RYANSTULC is offline
post #10 of 16 Old 07-23-2009, 10:40 AM
NahamshaStompa
HOLY S#@T Jeeprocks86!!! Did you make it through that spot in the second pic??
Its a rock..get over it!!!
NahamshaStompa is offline
post #11 of 16 Old 07-23-2009, 11:02 AM
JeepRocks86
yeah, with out even a dent on that day. If I remember correctly, I backed up and took it more strait on.
Harlan County, KY
Lion's den trail
For Sale:
post #12 of 16 Old 07-23-2009, 11:14 AM
wsm04rubi
Here's mine with 36" TSLs, 3" FT springs (actually netted about 4"), 1.25" BL and trimmed flares. Flexes great (with JKS control arms, trackbar and discos), only very minor rubbing at full lock turn when hard stuffed. Wheeled it on Pritchett Canyon, Moab Rim, Hell's Revenge, Cliffhanger, Seven Mile Rim, and Fins-n-Things back in May, no issues.
Bill
04 Rubicon -
wsm04rubi is offline
post #13 of 16 Old 07-23-2009, 04:39 PM
bddisi
I have 36x13.50 Iroks. They dont rub now but they have before. Here is a pic of now.
The now pic is 5.5 springs and 1 in body lift. 1.5 wheel spacers. 3in tube fenders.
Here is a pic of when I had the Xenons, they rubbed very little on the rear of the rear wheel well.
And here is a pic of when I had the Bushwackers, I also had 4in springs, 2in spacers and 3in body lift. The Bushwackers rubbed slightly.
I now have limiting straps and a rear Currie-Antirock, to help stop some of this.
Here is the rear limiting straps and the rear Currie-Antirock.
The jeep still flexes pretty well and I dont have to worry about the rear spring coming out.
Scorpion-Offroad-Concepts
bddisi is offline
post #14 of 16 Old 07-23-2009, 04:49 PM
bddisi
Sorry, here is a pic of the Bushwackers.
they rubbed the worst.
bddisi is offline
post #15 of 16 Old 07-23-2009, 08:21 PM Thread Starter
outlawjosywales
cool.........
Go Anywhere.
41 Iroks on a Rubicon jeepermom TJ Wrangler Technical Forum 36 01-24-2010 01:39 PM
36" iroks on d30 and d35... can they handle it.. jkm211 YJ Wrangler Technical Forum 5 08-22-2008 06:44 AM
36x13.5 iroks? z71offroader YJ Wrangler Technical Forum 14 01-01-2007 11:00 PM
? for people with IROKS McRoberts TJ Wrangler Technical Forum 6 10-16-2006 04:38 PM
SA and 36" Iroks? trance_junkie TJ Wrangler Technical Forum 11 06-26-2006 08:38 AM
