can i run 33s on 4.5 backspaced rims? - JeepForum.com
post #1 of 5 Old 09-01-2008, 11:45 AM Thread Starter
willbacker45
what do you guy think i have 3.75 well actually about 4in. of lift and cragar soft 8s with like 4.75 or 4.5 in. of BS?
so what do you guys think any one with a similar setup?
pics?
OR should i just go with the 10.50s
willbacker45 is offline
post #2 of 5 Old 09-01-2008, 11:46 AM
jbramble24
I run the soft 8s, 15x8 with 4.5" backspacing no problem. My lift is the RE 3.5" SF.
jbramble24 is offline
post #3 of 5 Old 09-01-2008, 11:53 AM
nic308
1978 CJ5
i run 4.5 bs on a 3in lift no rubbing
nic308 is offline
post #4 of 5 Old 09-01-2008, 12:28 PM
RedRubiconLJ
RedRubiconLJ's Avatar
2015 JK Wrangler
You may not have rubbing on the fender but you will on your ca's. I have 4"bs on my wheels with a 12.5" wide MTR and they just miss the ca's and I have no rubbing on the fenders.
You could always reduce your turning radius and adjust your steering stops so that doesnt happen.
2015 Red JKU Rubicon RK X-factor, Adams, Rockhard4x4, PSC, LoD, BFG, WARN
SOLD 2013 JKUR
Sold 2005 Rubi Unlimited
2004 TJ sold
1993 YJ sold
RedRubiconLJ is offline
post #5 of 5 Old 09-01-2008, 12:36 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
If you have any rubbing when the steering wheel is turned all the way left or right, you can add 1-2 washers to the steering bumpstops like is described at http://4x4xplor.com/steerstop.html
I ran 33x12.50 then 35x12.50 with 4.5" BS for several years and after I installed two washers per side, no more rubbing. My still tight turning radius wasn't increased enough to notice.
Jerry Bransford is offline
Difference in JK Wrangler spoke rims and JK Rubicon rims? CMT1 Wrangler General Discussion 3 09-04-2009 11:39 AM
Steel rims vs Alloy Rims oaklane Wrangler General Discussion 15 02-12-2009 08:28 AM
want new rims but can i reuse tmps from old rims? elfamiglia JK Wrangler Technical Forum 3 11-08-2008 07:41 PM
Question on Rubicon rims and moab accesories rims Krazy302 TJ Wrangler Technical Forum 9 11-13-2004 09:33 PM
Anyone Running 30's with 3" backspaced rims ? MusicMaverick YJ Wrangler Technical Forum 0 03-05-2002 07:08 PM
