Can I remove the steering and the trackbar at the same time? - JeepForum.com
post #1 of 10 Old 06-29-2013, 03:00 PM Thread Starter
ipath68
Or should I do one then the other, I don't want to screw everything up. I.e. replacing stock steering with Currie and also replacing the bds adjustable to jks adjustable.
ipath68 is offline
post #2 of 10 Old 06-29-2013, 04:04 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
No problem, simply install & get the track bar adjusted so the axle is centered first, before installing the rest of it. Then you can install the drag link & tie rod & adjust them so your steering wheel is straight & the toe-in is proper.
Jerry Bransford is online now
post #3 of 10 Old 06-29-2013, 11:55 PM Thread Starter
ipath68
Thank you sir
ipath68 is offline
post #4 of 10 Old 06-30-2013, 06:49 AM
AllTerrainJK
Don't let anyone turn the steering wheel while the drag link is disconnected from the piman arm. This could break the clock spring and it ain't cheep.
Roads? Where we're going we don't need roads!
AllTerrainJK is offline
post #5 of 10 Old 06-30-2013, 07:34 AM
rchase559
No it won't. The steering box has internal stops that prevent it from turning too far. I did some of the bleeding to my PS steering system with the drag link detached.
The issue occurs when you disconnect the steering shaft at any point. There is then nothing to restrict its rotation.
rchase559 is offline
post #6 of 10 Old 06-30-2013, 08:45 AM
AllTerrainJK
Wish someone would've told my old CS that.
post #7 of 10 Old 06-30-2013, 08:52 AM
AllTerrainJK
Unless I had an internal problem with the steering gear. I had to replaced that a month or so later. That time I bungee corded the steering wheel.
post #8 of 10 Old 07-01-2013, 10:56 AM Thread Starter
ipath68
So I set my toe in adjustment on my own, do I still need to get a front end alignment?
ipath68 is offline
post #9 of 10 Old 07-01-2013, 11:07 AM
Jerry Bransford
Administrator
Not if you got your toe-in adjusted properly, that's usually all that needs to be set if your adjustable control arm lengths are correct.
post #10 of 10 Old 07-01-2013, 12:02 PM Thread Starter
ipath68
Ok that's what I understood, I haven't messed with the control arms since the last alignment. Thanks again!
ipath68 is offline
