-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Can I remove the steering and the trackbar at the same time? (http://www.jeepforum.com/forum/f9/can-i-remove-steering-trackbar-same-time-1542840/)
ipath68 06-29-2013 02:00 PM
Or should I do one then the other, I don't want to screw everything up. I.e. replacing stock steering with Currie and also replacing the bds adjustable to jks adjustable.
Jerry Bransford 06-29-2013 03:04 PM
No problem, simply install & get the track bar adjusted so the axle is centered first, before installing the rest of it. Then you can install the drag link & tie rod & adjust them so your steering wheel is straight & the toe-in is proper. :)
ipath68 06-29-2013 10:55 PM
Thank you sir
AllTerrainJK 06-30-2013 05:49 AM
Don't let anyone turn the steering wheel while the drag link is disconnected from the piman arm. This could break the clock spring and it ain't cheep.
rchase559 06-30-2013 06:34 AM
No it won't. The steering box has internal stops that prevent it from turning too far. I did some of the bleeding to my PS steering system with the drag link detached.
The issue occurs when you disconnect the steering shaft at any point. There is then nothing to restrict its rotation.
AllTerrainJK 06-30-2013 07:45 AM
Wish someone would've told my old CS that. :)
AllTerrainJK 06-30-2013 07:52 AM
Unless I had an internal problem with the steering gear. I had to replaced that a month or so later. That time I bungee corded the steering wheel.
ipath68 07-01-2013 09:56 AM
So I set my toe in adjustment on my own, do I still need to get a front end alignment?
Jerry Bransford 07-01-2013 10:07 AM
Not if you got your toe-in adjusted properly, that's usually all that needs to be set if your adjustable control arm lengths are correct.
ipath68 07-01-2013 11:02 AM
Ok that's what I understood, I haven't messed with the control arms since the last alignment. Thanks again!
The time now is 09:40 AM.
