Can I remove the front drive shaft and still drive around? - Page 2 - JeepForum.com
post #16 of 59 Old 08-29-2010, 03:44 PM
Stu Olson
Stu Olson's Avatar
This is true....folks are still removing the front drive shafts....for the same reasons too.
Here is a write-up detailing a way to remove the TJ's front drive shaft. It also has info on removing the u-joints, etc.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #17 of 59 Old 09-26-2010, 05:51 PM
lakotaed
1994 ZJ
Never too old to learn?
Thank you for reviving this thread and providing me with exactly what I needed. I read a few threads that focused on the front end death wobble, which is not a shimmy by any stretch. Anyway, I have gotten tired of just replacing parts that everyone suggests, which I appreciate, but I still have the problem. A couple of the people removed their front axles and the wobble went away. I had a 76 Montego that had a wobble, but it did not feel like anything I am experiencing, but it was definitely in the drive train. It turned out to be a worn bushing that the shaft fit into.
I noticed about a 1 1/2 inch area on the shaft end near the TC that is polished. I assume it is sliding in and out as I am driving and is rubbing on something to shine it up. I am going to pull it, using your link, and see if the wobble weebles and falls down.
Thanks for keeping this one alive. Please do not turn this into a death wobble thread though, there are enough of them already.
lakotaed is offline
post #18 of 59 Old 11-06-2011, 10:24 AM
Kris5449
I bought a 97 TJ that the prior owner had removed the front drive shaft (didn't realize it until after I owned it as it was my first jeep). I suspect that it was the cause of my death wobble, but excluding that no other problems resulted.
Kris5449 is offline
post #19 of 59 Old 11-06-2011, 11:01 AM
Sgt_Utz
Wow... This is a thread that will never die... 7 years old now!
Sgt_Utz is offline
post #20 of 59 Old 11-06-2011, 04:59 PM
FZY1
This is a good thread that is still relevant even if it is 7 years old. I was just thinking of doing something similar.
FZY1 is offline
post #21 of 59 Old 12-13-2011, 11:32 AM
Vici0usX
I was looking for this answer as well. I've been leaving my front driveshaft off unless i'm four wheeling, saves money in the long run. Wasn't sure if it'd cause any damage but thanks for clarifying.
98 TJ Sport 4.0L
Vici0usX is offline
post #22 of 59 Old 12-13-2011, 11:38 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
If it does, and I'm not saying I believe it helps in the least, it'd be so insignificant to not be worth the effort. The front axle spins its ring & pinion gears no matter what and the t-case has a true neutral for the front driveshaft when in 2wd so I wouldn't even begin to think there's a bb in a boxcar's worth of difference with the front driveshaft being removed.
Jerry Bransford is online now
post #23 of 59 Old 12-13-2011, 11:58 AM
Vici0usX
I was talking about replacement costs for the driveshaft parts, such as replacing ujoints. I just don't see any point to my front driveshaft unless I'm four wheeling.
98 TJ Sport 4.0L
Vici0usX is offline
post #24 of 59 Old 12-13-2011, 01:14 PM
mdm
Farm Wheeler
The u-joints in the front drive shaft see very little stress when in 2WD. You are more likely to wear out the threads on the yokes repeatedly removing and installing the shaft than wearing out the u-joints. I guess this is rather subjective. Going off-road once a year is a lot different than if you are off-road every weekend, but I'd still leave the shaft in place.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #25 of 59 Old 12-13-2011, 09:28 PM
Sgt_Utz
Unless you have hubs in the front. But not sure a $900 upgrade is worth it for a practically invisible improvement in gas mileage.
Sgt_Utz is offline
post #26 of 59 Old 12-14-2011, 05:16 AM
mike_dippert
mike_dippert's Avatar
I've had my front shaft off for the better part of 2 years now (wheeling is pretty low on the priority list right now). The reason is because my DC joint started squeeling in winter, had it rebuilt in spring, started squeeling again the next winter. The centering ball is to blame in my case. I don't think the shop did honest rebuild on it, so I blame them for the second time.
I'm replacing it with a coast driveline shaft for a primary, and rebuilding the stocker myself as a back-up.
Cost savings is so negligent that planning your errand routes and driving efficiently will save you more money. $150 for my rebuild (which should have lasted 5 years) is $0.58/week. Even just 3 years is $1/week.
mike_dippert is online now
post #27 of 59 Old 12-14-2011, 05:29 AM
BillR
BillR's Avatar
You're correct in that there is no point to the front driveshaft of you don't need 4WD. Taking it off when it's not going to be needed for awhile reduces the wear on the ujoints and centering ball of the shaft. Manual hubs accomplish the same thing at a MUCH higher cost.
'11 JK Unlimited Sport S, stock for now...
'08 JK X, OEM rear locker and swaybar disco!
BillR is offline
post #28 of 59 Old 12-16-2011, 04:19 PM
Vici0usX
Yeah that's all I'm saying! I know I'm not going to save a lot of money but I dont have to worry about it anymore. Thanks for the info, I didn't know about manual hubs.
98 TJ Sport 4.0L
Vici0usX is offline
post #29 of 59 Old 12-16-2011, 04:23 PM
Vici0usX
Since I've moved, I have no idea where to go 4 wheelin' and the places I know are far away. That being the case and I don't have much time anymore as I'm always busy with work. That's why I said, if you don't 4 wheel, a front driveshaft is pointless to have and something else to worry about. My jeep makes enough sounds as it is
98 TJ Sport 4.0L
Vici0usX is offline
post #30 of 59 Old 07-30-2012, 09:03 AM
Mystic1031
It is helping someone today I'm pulling my front drive shaft today
Mystic1031 is offline
OK to remove rear drive shaft??? coorsmgood TJ Wrangler Technical Forum 16 08-31-2011 07:53 PM
I have a drive shaft problem=2 drive shafts in less than one week!!!!!! machoman YJ Wrangler Technical Forum 14 12-24-2010 08:39 PM
What size wrench will I need to remove Front and rear drive shaft? Jeepsr4me19 YJ Wrangler Technical Forum 3 08-28-2009 04:57 PM
Canniblize front drive shaft to fix the rear CV shaft? Scotch740 TJ Wrangler Technical Forum 11 11-28-2008 03:33 PM
front drive shaft anderson sc YJ Wrangler Technical Forum 8 12-31-2007 10:38 AM
