Can i put the positive cable to the negative? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Can i put the positive cable to the negative?
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 03-08-2006, 12:55 PM   #1
Nickb1907
Im trying to do a PCM flash and it requires "discharging the capacitors in the memory" by touching the positive battery cable to a ground. Will the negative terminal work for a ground? Or will it blow up and kill me
If anyone else has done the PCM flash does it show you in any way that the memory is reset?
Nickb1907 is offline   Reply With Quote Quick reply to this message
Unread 03-08-2006, 01:01 PM   #2
RAAB3485
Viewer Discretion Advised
RAAB3485's Avatar
Touching the postive to the negative battery terminal should do the same thing as touching it to the ground because if you follow the wires off the negative battery terminal they just run to the chassis.
Eric
Colorado Jeep Club Member #1
RAAB3485 is offline   Reply With Quote Quick reply to this message
Unread 03-08-2006, 01:01 PM   #3
jzmtl
Depends on how big the capacitor is, you'll get some sort of spark. But do what it says and find a ground, better safe than sorry.
jzmtl is offline   Reply With Quote Quick reply to this message
Unread 03-08-2006, 01:18 PM   #4
Nickb1907
still no definete answer.... is the motor mount bolt a good ground?
Unread 03-08-2006, 01:20 PM   #5
RAAB3485
RAAB3485's Avatar
Anything that goes to the chassis is a good ground. You can touch the engine even. Frame, bolts going to the frame, negative battery terminal, axles, all are bolted to the frame.
Eric
Unread 03-08-2006, 01:24 PM   #6
CNY
I guess the important thing is to remember we're talking about doing these things disconnected from the battery.
........by touching the positive battery cable to a ground. Will the negative terminal work for a ground.......
So, yes, you can disconnect the positive battery cable, and touch it to the disconnected negative battery cable.
CNY is offline   Reply With Quote Quick reply to this message
Unread 03-08-2006, 01:27 PM   #7
Nickb1907
ya i was talking about doing it to the connected negative cable, a voice in my head was saying no, so i thought i would check
Unread 03-08-2006, 01:33 PM   #8
UK 4X4
That does'nt read right to me,
normally when deflashing eproms you disconnect the chips positive input wire and short the chips pin to negative.
Not the +supply cable as that will just cause a short.
With most engine managements systems if you disconnect the battery for 20 mins Plus the system resets to factory defaults and re-learns the engines best settings.
UK 4X4 is offline   Reply With Quote Quick reply to this message
Unread 03-08-2006, 01:47 PM   #9
Toombs
Think about this for a second. The frame and engine and body are only "grounded" when the negative battery cable is connected. Touching the disconnected positive battry cable to the frame is exactly the same as touching it to the still connected negative cable.
Mike
[URL="http://toombsracing.com"]ToombsRacing.com[/URL]
Toombs is offline   Reply With Quote Quick reply to this message
Unread 03-08-2006, 02:04 PM   #10
CNY
ya i was talking about doing it to the connected negative cable, ......
Originally Posted by Toombs
......Touching the disconnected positive battry cable to the frame is exactly the same as touching it to the still connected negative cable.
Yes, disconnecting the positive cable and touching it to the connected negative cable would be fine (and accomplish the same thing as touching the + cable to any ground point in the car.
My suggestion to have both cables disconnected was over-doing it.
Unread 03-08-2006, 07:39 PM   #11
Nickb1907
i did it and my jeep blew up, J/k
The hole time i was ducking for cover though
Unread 03-08-2006, 07:48 PM   #12
VisitorJim
the JEEP wounldn't have blown up, you just would have been sprayed with sulfuric acid... probably boiling sulfuric acid, if that happened at least you could collect disability, there's always a bright side
[SIZE=2][COLOR=DarkGreen][B] 1997 TJ Sport [/B] [/COLOR] [/SIZE]
3.5" RE Super Flex, Daystar 1"BL/MML, 33x12.5 ProComp MT's on Black Steel, 4.56 Gears, Front Lock-Rite, NV3550 swap, 33 Eng Skid, LuK ProGold Clutch, AA SYE, Tom Woods Front and Rear, Full Borla Exhaust, Turbo City Intake, Optima Red Top, Alloy USA Axle Seals, PSC Rockers, KC Daylighters, Xenon Flares, and lots of other small stuff that adds up $$$
[URL=http://community.webshots.com/user/visitorjim]Pictures[/URL]
[COLOR=Blue]1990 Kawasaki EX 500[/COLOR] - work in progress - more work than progress...
VisitorJim is offline   Reply With Quote Quick reply to this message
Unread 03-08-2006, 07:51 PM   #13
Nickb1907
that would have been so worth it so that i can get a handicap spot with a scar on my face. I hate how people take advantage of that.
