Can I get some cheese with my Whine? - JeepForum.com
post #1 of 4 Old 10-01-2012, 04:20 PM Thread Starter
esynol
Hey All,
I have a whine in 1st through 3rd gear. It only happens when I am in gear and have the clutch out. If I have the clutch in or its in neutral, it dose not whine
I thought I would of fixed my whine after filling up my trans and transfer case after replacing some leaky seals. I drove it around today, thinking maybe some oil needed to be worked into the whining part, but it is still whining.
Any thoughts?
I have an ax-15 trans and a Np 231 transfercase
esynol is offline
post #2 of 4 Old 10-02-2012, 06:28 PM
mukluk
Are you sure the whine is coming from the transmission or transfer case? Could the noise possibly be coming from your rear differential?
mukluk is offline
post #3 of 4 Old 10-02-2012, 06:54 PM Thread Starter
esynol
Yea, i think so, because when i push in the clutch, the whining stops, but I will check my levels tomorrow. Thanks
esynol is offline
post #4 of 4 Old 10-05-2012, 03:59 PM Thread Starter
esynol
Bump, I just topped off my diffs, so the whine is not that. I then put my transfer case into neutral, and the whine was still there, so i guess it has to be a bearing in there
esynol is offline
transfer case , transmission noise , whining noise
Tire Warranty - Necessity, or Extra Cheese? CysMyGuy JK Wrangler Technical Forum 13 10-08-2011 04:37 PM
String Cheese Dilemma (Now including recovery video) Corleone JK Wrangler Technical Forum 25 02-08-2011 07:12 PM
Whine around 15-35 mph spyderbyte TJ Wrangler Technical Forum 25 07-08-2010 07:54 AM
Want some cheese with that whine (transmission?) (with video) tinklybear YJ Wrangler Technical Forum 4 05-29-2010 07:24 PM
whine in 4 lo jeepgeek2k TJ Wrangler Technical Forum 15 12-18-2009 11:59 PM
