Can I drop in a Ford Expedition 2003 into a 98 TJ??? - JeepForum.com
post #1 of 6 Old 05-30-2012, 12:46 PM Thread Starter
S_nner
Can I drop in a 2003 Ford Expedition axle into a 98 TJ???
2003-2004 EXPEDITION Rear Axle; (3.73 ratio), 9.75" ring gear is it possible for this to go into my TJ and what would I need to do it...... ?? Welding, grinding, plug n play? Any help would be wonderful....
-Matt
S_nner is offline
post #2 of 6 Old 05-30-2012, 12:52 PM
SideshowBob024
Essentially every bracket needs to come off. Do a search, there is TONS of info on this forum and elsewhere on this swap.
You could use this-
http://artecindustries.3dcartstores....uss_p_233.html
http://www.stu-offroad.com/axle/8.8axle/8.8axle-1.htm
SideshowBob024 is offline
post #3 of 6 Old 05-30-2012, 12:57 PM Thread Starter
S_nner
Now when it comes to the Ford 8.8 are the all universal when it comes to length and specs no matter what year vehicle it came off of.... Like is a 1987 Ford F-150 8.8 axle and a 2003 Expedition 8.8 axle synonymous when it comes to the same swap procedures?
S_nner is offline
post #4 of 6 Old 05-30-2012, 01:10 PM
FFjeepguy
i dunno about all 8.8 being identical, i dont believe they are? but u will be better off with an 8.8 out of an explorer from 95 to newer because they had the disc brakes and they have the same lug pattern as the tj
FFjeepguy is offline
post #5 of 6 Old 05-30-2012, 01:57 PM
SideshowBob024
Oh you said expedition.... wouldn't that be a wider axle?
post #6 of 6 Old 05-30-2012, 09:27 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Much wider.
The reason explorer axles see used is because that are the correct width, have the best shafts, and come with disc brakes and several gearing options
Mustang axles have the weak 28spl shafts, f150's can have either shaft count but are wider.
ratmonkey is offline
axle , dana 44 , dana 44 swap , ford , tj
Transfer Case Drop Question...To drop or not to drop? dswi YJ Wrangler Technical Forum 11 07-24-2009 02:33 PM
T Case drop for 2003 and later TJ's silverbacktj TJ Wrangler Technical Forum 15 02-08-2009 03:22 PM
rubicon? (2003 Rubi vs. 2003 Sport) Tom1 TJ Wrangler Technical Forum 10 09-08-2008 07:24 PM
replace 2003 skid plate with <2003 frankske_ TJ Wrangler Technical Forum 5 04-08-2007 06:00 PM
Transfer case drop for a 2003 Sahara seanbsahara TJ Wrangler Technical Forum 1 03-05-2004 02:24 PM
