Can I drive my TJ Without the front driveshaft installed? - Page 2 - JeepForum.com
post #16 of 37 Old 04-25-2012, 07:18 PM
iluvcowjuice
1979 CJ7
Originally Posted by ColoradoCole View Post
Does a tree make a sound when it falls in the woods and no one is around?
Yes you can
It doesn't, if there is no one around to interpret the vibrations caused by the tree into sound, they are just vibrations, not sounds.
But you can still drive without a front driveshaft.
iluvcowjuice is offline
post #17 of 37 Old 04-25-2012, 07:45 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
It does.
Sound is a physical movement, you don't have to hear it for it to exist...
Knuckelhead is offline
post #18 of 37 Old 04-25-2012, 07:55 PM
RaggedOleMan
Of course it makes a sound. The fact that no one is there to hear it, doesn't mean the sound wasn't produced, just that it wasn't heard...even a blind man can feel the heat of the sun...
RaggedOleMan is offline
post #19 of 37 Old 04-25-2012, 08:57 PM
Y1ann188
one of my buddys in high school kept his front DS out and only put it back in for wheelin trips, he claimed he got better gas mileage, which if i remember right he did... maybe 20-30 miles more a tank? who can remember that far back
'03 TJ 4.0L NV3550 D30/D44 4.5" RE LA 4.56s, TW DS/AA SYE 35" BFG KM2's Bilstien 5150s JCR Offroad Stubby Winch Front Bumper JCR Offroad Rear Bumper BTF Rock Sliders Warn XD9000i KC Lights Kilby Skids
XD9000i FOR SALE === $950 OBO
Y1ann188 is offline
post #20 of 37 Old 04-25-2012, 08:59 PM
sjones26573
Why are people arguing on a dead thread brought back by a smiley?
EDIT: Even if it is about trees (now that I read closer)
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #21 of 37 Old 04-25-2012, 10:07 PM
dongalonga
I like trees. They smell nice
dongalonga is offline
post #22 of 37 Old 04-25-2012, 10:22 PM
Knuckelhead
AFSOC Retired
Go back to your corner...
post #23 of 37 Old 04-25-2012, 10:59 PM
sjones26573
It's cold over there...
Jeep-Owner.com
post #24 of 37 Old 04-25-2012, 11:24 PM
Knuckelhead
AFSOC Retired
Your still in warm company...
post #25 of 37 Old 04-25-2012, 11:31 PM
AKGeo
Originally Posted by mdm View Post
While it is correct that running with only one of the driveshafts presents no problems with at TJ, your logic is faulty.
Until, I dunno, you start puking atf out of the rear output on a stock slip-yoke 231. But what do I know...apparently I'm not knowledgeable at all about how a transfer case works.
AKGeo is offline
post #26 of 37 Old 04-26-2012, 01:08 AM
wushaw
Rockin jeep
wushaw's Avatar
Here is a picture of a 231, now tell us where this leak is gonna come from? Are you thinking the 231 is like a 2wd automatic tranny where the slip yoke actually goes into the tail housing of the tranny?
wushaw is offline
post #27 of 37 Old 04-26-2012, 01:15 AM
AKGeo
From between the splined output shaft visible in that image and the seal meant to hug the outer spline shaft that's missing. Behind that harmonic dampener (which I don't have, btw) is the seal and bearing. The seal has a gap between its inner diameter and the output shaft, meant to be taken up by the internally splined tube attached to the ujoint yoke on the driveshaft itself. Illustrated in the pictures in this thread:
http://www.jeepforum.com/forum/f37/n...eak-fix-82091/
It's a different tailshaft housing, but the idea is still the same. What you see there isn't completely sealed. Prove me wrong. It's entirely possible. But I don't think so. It's entirely possible that the design changed to remove that tailshaft and place the seal directly into the speedo sensor housing seen behind the harmonic dampener, and that's what I learned way back in the day. The old style cases WILL leak oil through the bearing and those splines. Quite possible that it won't leak from the newer style. Meh.
AKGeo is offline
post #28 of 37 Old 04-26-2012, 01:24 AM
Knuckelhead
AFSOC Retired
Wait for it, keep in mind that TJ NP231's don't leak fluid when the slip yoke is removed...
post #29 of 37 Old 04-26-2012, 02:17 AM
wushaw
Rockin jeep
wushaw's Avatar
Ok,
look at fig 3, where is the seal? Is the accordion boot the seal?
Fig 5 shows the seal.
http://www.4xshaft.com/np231shortsha...dyokekitv2.pdf
wushaw is offline
post #30 of 37 Old 04-26-2012, 04:17 AM
mdm
Farm Wheeler
...that's what I learned way back in the day. The old style cases WILL leak oil through the bearing and those splines. Quite possible that it won't leak from the newer style. Meh.
The problem is that we are talking about the TJ transfer case and not the one you learned about "back in the day". There was a time when just about every time an airplane landed the mechanic would need to replace at least one of the cylinders. When was the last time you saw that happening on the plane sitting at the gate waiting to board passengers?
"Back in the day" makes for fond memories that too often don't apply to today.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
front drive shaft , drive shaft
Just installed 8.8 - Driveshaft length? Steve O TJ Wrangler Technical Forum 6 06-07-2010 12:32 AM
Front driveshaft removed can I still drive GreenTJ420 TJ Wrangler Technical Forum 5 03-07-2010 12:54 PM
disco rear driveshaft, drive with front d44? MC_NickP TJ Wrangler Technical Forum 11 09-11-2009 12:27 PM
Squeaky Front driveshaft...safe to drive for a while? JeepinYahoo TJ Wrangler Technical Forum 19 12-01-2006 02:36 PM
Front driveshaft, able to drive with it disconnected Joezilla YJ Wrangler Technical Forum 3 03-19-2006 12:46 PM
