Can I drive my TJ Without the front driveshaft installed? - JeepForum.com
post #1 of 37 Old 07-25-2010, 02:12 PM Thread Starter
2000-TJ
will it do any damage to my TJ if I drive it about 40 miles without the front driveshaft installed? everything is sealed so no prob there but I'm wondering about the if the absence of driveshaft load on the T-case might cause problems?
2000-TJ is offline
post #2 of 37 Old 07-25-2010, 02:25 PM
AFjeepMan
nope...no problems at all
2005 Wrangler TJ, 3 1/4" RC lift, Cragar Soft 8's 32" BFG Mud Terrains, Smittybilt SRC D-Ring bumpers, Smittybilt XRC8 winch, Body Armor Rockcrawler side guards
[_l_,[____],
l----L - OlllllllO-
(o)_) (o)_)--)_)
Wife≥Jeep>GF
Relearn your priorities.
WANTED: SYE and cv shaft...good condition and good price. for a TJ with about 5-6" of lift.
AFjeepMan is offline
post #3 of 37 Old 07-25-2010, 02:26 PM
superslayer
If you can run without a rear driveshaft in 4HI you'll be absolutely fine with no front driveshaft in 2HI.
superslayer is offline
post #4 of 37 Old 07-25-2010, 02:26 PM
nitecop
no problem at all with doing that.
Jim
USW, OAPSE Union member
99 TJ Sahara 4.0 5-Sp FUV + farm worker
Project f-Xj F150/XJ Ford eXtreme jeep combo
06 6 Speed LJ my daily driver.
Colorado Jeep club memeber #505
nitecop is offline
post #5 of 37 Old 07-25-2010, 02:42 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
yup no problems.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #6 of 37 Old 07-25-2010, 03:15 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
And what would be hurt in 4hi?
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #7 of 37 Old 07-25-2010, 03:17 PM
wushaw
Rockin jeep
wushaw's Avatar
This is a trick question....isn't it?
wushaw is offline
post #8 of 37 Old 04-23-2012, 09:30 PM
schaan
schaan is offline
post #9 of 37 Old 04-24-2012, 01:08 AM
ColoradoCole
Does a tree make a sound when it falls in the woods and no one is around?
Yes you can
ColoradoCole is offline
post #10 of 37 Old 04-24-2012, 04:16 AM
mdm
Farm Wheeler
While it is correct that running with only one of the driveshafts presents no problems with at TJ, your logic is faulty.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #11 of 37 Old 04-24-2012, 06:38 AM
wazilian
I had it out for a few months a while back. In fact I had the thing inspected while the drive shaft was out.
Black '97 TJ Sport 4.0L Auto 112,000 miles
BFG AT 30's, Skyjacker Hydros, JKS Quick Disco's
Dynomax Super Turbo CatBack
Black Hard Top...when its on
Garfield Air Freshener
And there's a frame under there too...I've seen it
wazilian is offline
post #12 of 37 Old 04-24-2012, 07:29 AM
kittenmittens
kittenmittens's Avatar
i went to double double cardan and when i removed my t case drop i removed the drive shafts and didn't put the front back in. probably wont until the next time i go to Uwharrie. 2wd with Rubicon locker override does most local trails anyway.
05 Rubicon 6" lift 35x12.5 BFG KM2
15 Rubicon Unlimited Hard Rock 2.5" lift 35x12.5 BFG KM2
kittenmittens is offline
post #13 of 37 Old 04-24-2012, 08:14 AM
tators
I know of several folks who keep there front driveshaft disconnected unless 4wheeling....
A slight dent in your driveshaft, means a slight bend, means vibration on the highway... - disconnecting your front driveshaft is a poor mans solution to eliminating highway vibrations due to slight front driveshaft problems.
tators is offline
post #14 of 37 Old 04-24-2012, 08:20 AM
tators
I just remembered back in the day... I had a 2000 TJ, and drove from Tennessee to Michigan and back with my front driveshaft disconnected from the axle and zip-tied to the frame.... (too long of a trip to put up with slight front driveshaft vibe)
tators is offline
post #15 of 37 Old 04-25-2012, 07:14 PM
kittenmittens
haha thats to funny. but i would have done something like that 2. way to long of a drive for vibrations. i remember when i first pulled my t case drop before i had my double cardan drive shaft at 65 the vibes would put my *** to sleep!
front drive shaft , drive shaft
Just installed 8.8 - Driveshaft length? Steve O TJ Wrangler Technical Forum 6 06-07-2010 12:32 AM
Front driveshaft removed can I still drive GreenTJ420 TJ Wrangler Technical Forum 5 03-07-2010 12:54 PM
disco rear driveshaft, drive with front d44? MC_NickP TJ Wrangler Technical Forum 11 09-11-2009 12:27 PM
Squeaky Front driveshaft...safe to drive for a while? JeepinYahoo TJ Wrangler Technical Forum 19 12-01-2006 02:36 PM
Front driveshaft, able to drive with it disconnected Joezilla YJ Wrangler Technical Forum 3 03-19-2006 12:46 PM
