Can I drill holes in my frame to raise my rock sliders up 1" - JeepForum.com
 5Likes
post #1 of 17 Old 06-16-2017, 11:33 AM Thread Starter
Fargo
Years ago I purchased Jeeperman rock sliderz. I later installed a body lift. So now my sliderz sit 1" lower than the body. Can I just drill a couple holes in my frame to raise my sliderz 1" higher. My concern is that I will loose frame strength if I drill a bunch of holes in the sides of the frame. My other concern is those holes are another place for rust to from. But my biggest concern is the lose of strength to the frame.
6spd manual
LJ Owners Group member #110
Fargo is offline
post #2 of 17 Old 06-16-2017, 11:39 AM
elpaisa
Of course you can. The Mfg. However is going to recommend against doing so. And if you do drill holes just rattle can the exposed metal
Sent from my SM-N920T using Tapatalk
elpaisa is offline
post #3 of 17 Old 06-16-2017, 01:41 PM
Shark_13
There are a ton of holes in the frame already. Drilling a couple more won't hurt anything.
Let's wait for the other guys to chime in against drilling holes
Shark_13 is offline
post #4 of 17 Old 06-16-2017, 01:47 PM
TJnBC
It wont hurt. Just be sure to try and paint the holes afterwards.
2006 LJR...the madness begins again
TJnBC is offline
post #5 of 17 Old 06-16-2017, 02:29 PM
biffgnar
biffgnar's Avatar
IMO the real issue is frame v. tub mounted sliders. Once you are committed to frame mounted (as OP obviously is), do whatever you want.
Romney in 2020!
biffgnar is offline
post #6 of 17 Old 06-16-2017, 04:00 PM
Gary2
I had read some place where there was a minimum distance from the edge for drilling in the frame. May be more to it than we think. You may want to research that some.
Gary2 is offline
post #7 of 17 Old 06-16-2017, 04:17 PM
Dodger60
Holes in structural metal parts should be as a rule of thumb 1.5 times diameter away from the edge..that is center of hole to edge.
On the frame you have a formed radius 'corner' you don't want to infringe upon either.
Yeah I am a mechanical designer so I run into these issues regularly.
A round hole in a frame member won't weaken it if you're not to close the edge. Far enough away and it makes nearly zero impact..too many holes too large and then​ you have issues!
Sent from my Nexus 5 using Tapatalk
Shark_13 likes this.
Dodger60 is offline
post #8 of 17 Old 06-17-2017, 12:13 AM Thread Starter
Fargo
Wow great info. Thank you.
Justs to be clear. You said 1.5 times the hole diameter to the edge measured on center correct? So a 1" hole measured on center would be drilled 1 1/2" away from the edge? Thus putting the edge of the hole 1" away from the edge of the material?
Dodger60 likes this.
6spd manual
Fargo is offline
post #9 of 17 Old 06-17-2017, 12:54 AM
1badxj
Did it for mine.........the sliders i had custom built attach to the frame in three points and bolted with two 1/2in grade 8bolts each.
2005 Rubihara #111 of 1000 (for sale:
1badxj is offline
post #10 of 17 Old 06-17-2017, 05:44 AM
Dodger60
Yes but hopefully you aren't using 1" bolts!
There is a maximum amount of removed material as well but that is more complicated...
Dodger60 is offline
post #11 of 17 Old 06-17-2017, 10:56 AM
freeskier93
There are quite a few holes from the factory that violate your rule.
freeskier93 is offline
post #12 of 17 Old 06-17-2017, 08:02 PM
Dodger60
LOL.. exceptions that prove the rule!
I have had engineers approve structure that breaks the rule and make me change ones that follow it..it's a rule of thumb not a hard rule of design..one if the reasons I love what I do!
Dodger60 is offline
post #13 of 17 Old 06-17-2017, 09:05 PM
JeepnBlake
If the second set of holes really bother you that much just weld them shut. My $0.02
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #14 of 17 Old 06-19-2017, 10:57 AM Thread Starter
Fargo
LOL - No not using 1" bolts. It was just easy math for the example. I would use the bolts Jeeperman sent with the sliders. They are about 3/8".
Thank you 1badx for the pictures. It gave me another idea. My mounting plats run veritcle to bolt around the frame. I like how yours run more horizontal. That would make it easier if I dicide to bolt through the frame directly as you did.
I did come up with another idea this weekend on how I might be able to modify the slider and keep the the original frame mounted system. So I know how 2 new ideas. I'll ponder over them and see what I come up with. Thanks for all the help guys.
6spd manual
Fargo is offline
post #15 of 17 Old 06-19-2017, 11:38 AM
Dodger60
That's good to ponder to find the best way for you and your abilities/equipment...
Keep us updated??
Dodger60 is offline
