Can I do this? Adding more lift to RC Series II 4" lift. Body lift or coil spacers? - JeepForum.com
post #1 of 21 Old 09-11-2010, 08:51 PM Thread Starter
gattaca37
Can I?
Just purchased rough country series II 4" susp lift, was lookin at a 3" body to go with it. Asked rough cou if I could do 1.75"coil spacer over a body lift and they said u shouldn't, now I talked 2 a guy 2nite and he says he runs a 4"susp w/ 2" coil spacers. Here is what is comin from rough cou:4" susp lift w/ 2.2 shocks, 2" tcase drop. Is this possible w/ the new 2.2 shocks (lift+coil pucks) that r comin w/ 4" susp lift (or will they be 2 short) Will driveshaft be ok (no slip yoke eliminator right now, and not purchased ). Is this even possible to do a 4" lift w/ 1.75"coil spacer? Do u need longer shocks and modified dshaft for coil puck lifts? Should I stick w/ 4" susp and 3" body? What's pros and cons of each? Thanks for help
gattaca37 is offline
post #2 of 21 Old 09-11-2010, 08:55 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
you dont need a 3" BL on top a 4" of SL. buy their 1.25" BL and call it good.
to mount any coil spacer on top of 4" of SL is risky. when i say risky, i mean you might have to drop your skid plate 3" instead of 2". 5.75" of SL minus 3" TCD equals a ground clearance gain of 2.75"... is it worth it?
Mail crawling.
MisfitSeven is offline
post #3 of 21 Old 09-11-2010, 08:56 PM
Meep97
2009 JK Wrangler
if you go over 4" you will need a SYE.. and if you go any higher than the 4" lift you will have to replace the shocks that RC gave you to match the height that your going to
Meep97 is offline
post #4 of 21 Old 09-11-2010, 08:58 PM
js912
agree with previous post dont go with the 3inch body its just too much. i have 2in and at times its too much for my liking. it makes your jeep appear to have big akward gaps.
But always remember it is YOUR jeep
2000 Wrangler Sport (Silver)
D30/Ford 8.8 4.88 gears lock-rite, Front/rear bumpers Bushwacher flairs
RE 4.5 with 2in bl 35in trxus m/t Black steel wheels Warn Winch
js912 is offline
post #5 of 21 Old 09-11-2010, 09:18 PM
brunosplace
How large of tires are you planing to run? Have you re-geared to handle the tires? What rear axle do you have? As previously stated, more than 4" on the suspension will pretty much require an SYE kit and double cardan shaft. I personally would not go over 1.25" of body lift, as I think it looks tacky. Fill out your profile so we know more about your Jeep.
Originally Posted by Boodyrider View Post
Big tires, done right, are FREAKING EXPENSIVE. Deal with it, or don't go there.
Originally Posted by woodnjeep View Post
I live in the land where they salt cure roadkill.
97 Jeep TJ Sport, 4.0L, Auto, 3" BDS Lift (SOLD)
98 Jeep ZJ Laredo 4.0L, Auto, Stock
, parted out and scrapped
96 Jeep XJ Sport, parted out and scrapped
brunosplace is offline
post #6 of 21 Old 09-11-2010, 09:22 PM
Recoil
Recoil's Avatar
1988 MJ Comanche
Just get a 7" body lift and call it a day.
lol
Recoil is offline
post #7 of 21 Old 09-11-2010, 09:27 PM
Meep97
2009 JK Wrangler
just go with the RC 4" its what i have and its great for its price.. and you wont need a SYE
Meep97 is offline
post #8 of 21 Old 09-12-2010, 01:20 AM Thread Starter
gattaca37
right now jeep is completely stock, looking at going with 33s, so i can still use as daily commuter (spring, summer, fall, here in michigan). i was just lookin at safe max height before it starts getn expensive. so u guys say the 4" w/ 125-1.5 BL? My kid brother has a 3" (that is all he has) with 33s and it looks fine and handles fine, is this ok because he isnt sitting on an additional 4" SL?
post #9 of 21 Old 09-12-2010, 03:30 AM
ArrizX
1997 XJ Cherokee
ninja edit
hahahahah nevermind.
ArrizX is offline
post #10 of 21 Old 09-12-2010, 04:57 AM
crusher242
If you're looking for 33" skins, IMHO, just do a 3" suspension lift an a 1 1/4" BL. You'll never regret it.
Hold onto something... Quick!!!
crusher242 is offline
post #11 of 21 Old 09-12-2010, 05:31 AM
redo4x
4 inch suspension is plenty for 33's.
redo4x is offline
post #12 of 21 Old 09-12-2010, 05:40 AM
liveanadventure
4 SL is plenty for 33s youll be happy any higher with 33s will look silly ... kinda like a bobbin head doll
liveanadventure is offline
post #13 of 21 Old 09-12-2010, 05:44 AM
robncar
robncar's Avatar
About 4" is the limit for a short arm suspension. The control arm angles become very steep and the ride will suffer. You'll need longer shocks and brake lines.
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #14 of 21 Old 09-12-2010, 05:57 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I run 35's on a 4" suspension lift and to me it looks good. Running more than 4" of lift with 33's will look a little goofy IMO.
xjfever is offline
post #15 of 21 Old 09-12-2010, 06:49 AM
WeezyBlue
I have a 3.25" RC lift and 1" body lift and at times it makes my 33s look small, but I just wanted the extra room for suspension travel with the wheels cut...
7" and 33s will look ridiculous, especially with how obvious that body lift gap is going to be when you can see it's entire length above the tire...
But like somebody stated before, it IS your rig.
KD8UCX
CURRENT: '05 TJ Rubicon
Past: '06 TJ SE
WeezyBlue is offline
Cheaper lift, body lift? coil spacers? northeastern JK Wrangler Technical Forum 41 09-30-2009 05:58 PM
Adding coil spacers to RC 2.5 Suspension Lift gpower77 TJ Wrangler Technical Forum 17 08-24-2009 10:46 AM
Does anyone see a problem adding RE coil spring spacers to a Re 3.5 lift? Darkhrse99 TJ Wrangler Technical Forum 18 06-15-2009 04:21 PM
lift...body lift or coil spacers? PC'sJeep TJ Wrangler Technical Forum 3 10-28-2005 01:38 PM
adding coil spacers to suspension lift stingray TJ Wrangler Technical Forum 5 07-24-2005 02:44 AM
