Can anyone tell me the proper PSI for 30/9.50 BFG AT ? - JeepForum.com
post #1 of 2 Old 08-13-2003, 10:47 PM Thread Starter
Pkibugu
I've had my Jeep for a week now, and a few days ago I took a trip to the Llano River in TX, and the guys had me air down to about 12. I've been looking on the tire, and I think it's either worn off or just not listed, but reairing I went up to 30PSI. Im thinking thats about proper inflation, but can anyone please give me specifics? Thanks.
Pkibugu is offline
post #2 of 2 Old 08-13-2003, 11:47 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Don't worry about the air pressure found molded onto the sidewall of a tire, that is only its maximum allowable air pressure for use when the tire is carrying its maximum rated weight. So since your tires are only carrying maybe half of that max weight, the proper air pressure would be about half of whatever that air pressure on the sidewall would be, if you could see it.
30-33 psi is fine for your Jeep. 30 psi if it's fairly unloaded, a slightly higher psi like 33-34 if the Jeep is fully loaded with passengers, gear, etc..
Jerry Bransford is offline
Looking for proper name Scramblinlife TJ Wrangler Technical Forum 2 08-31-2009 07:36 PM
Proper way to lower the top 73Dart YJ Wrangler Technical Forum 6 05-05-2009 09:50 PM
Proper Bilsteins for 98 TJ Didley TJ Wrangler Technical Forum 6 05-02-2009 05:10 AM
Proper torque for hub happymudder10 TJ Wrangler Technical Forum 3 09-30-2008 07:18 PM
Proper Bumpstops 3stripes TJ Wrangler Technical Forum 10 02-06-2007 08:10 PM
