Can an 8.8 handle 36 or 37's? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Can an 8.8 handle 36 or 37's?
Hey Guys - Extreme Terrain Jeep Outfitters - ExtremeTerraiSPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!NEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WD
Unread 03-28-2005, 09:55 PM   #1
BNovak
Just wondering for the long run, or if I should look for another axle (was thinking maybe the 9" from a ford F150)
Thanks.
-BN
'97 Forest green. ~6" total lift, 8.8, etc. 36" TSL's, winch. You get the drill.
BNovak is offline   Reply With Quote Quick reply to this message
Unread 03-28-2005, 09:58 PM   #2
JSBlu974X4
if 31 spline yes, i wouldnt be too crazy on the pedal.
2005 Unlimited Rubicon Hard N Soft Tops, Clayton Long Arm on RE Coils, Warn Bumper/Tire Carrier, Warn Winch N Bumper, Currie Steering, JKS Quicker Disconnects, JKS Front Trac Bar, Bilsteins, CO2 System..Yada Yada Yada
JSBlu974X4 is offline   Reply With Quote Quick reply to this message
Unread 03-28-2005, 10:47 PM   #3
Chris_L
35's would be best for an 8.8. 37's would eventually kill it. If your going over 35's, look at a HP dana 60.
Buggy on 40's
Chris_L is offline   Reply With Quote Quick reply to this message
Unread 03-28-2005, 10:53 PM   #4
CreightonRea07
why not go w/ the ford 9. depending on which one you get, it can be stronger than a 60
Me:
2000 TJ Sport
Dana 44
4.0L 5-speed
33x12.50 bfg Muds
MORE sport cage
re 4.5 w/ 3.5 springs
[URL=http://www.tamor.org/members-rigs/Creighton-Rea]Pics[/URL]
Little Brother:
'92 Cherokee Laredo
Stock but soon to be lifted
235/75 BFG All-terrains
lots of dings and scratches
CreightonRea07 is offline   Reply With Quote Quick reply to this message
Unread 03-28-2005, 10:58 PM   #5
wipedawg
also the 9in isn't near as chubby as the d60
Silver Jeep Club Member # 829.3
6 in lift, 35" Interco Trxus MT's, long armed, Bushwacker cut-out flares, Skyjacker coils(powdercoated grey), RE 4.5 extreme duty leaf packs, Tera 1.5in shackles, AJ's Superrails, AA SYE, TW DS, Blacked out all around. and a buncha RE trackbar stuff, and the infamous ZJ tierod :)
wipedawg is offline   Reply With Quote Quick reply to this message
Unread 03-28-2005, 11:06 PM   #6
Chris_L
Hmmm....mine has more clearance than a 9"
Also the HP 9" carries an 8.8 ring gear and is not a true 9". The low pinion nine hangs like a boat anchor.
Buggy on 40's
Unread 03-29-2005, 08:46 AM   #7
jc97xj
You can get a true high pinion 9 that does not use 8.8 gears.
http://www.truehi9.com/
04TJ X
12JKU Rubi
jc97xj is offline   Reply With Quote Quick reply to this message
