Can an 8.8 handle 36 or 37's? - JeepForum.com
post #1 of 7 Old 03-28-2005, 08:55 PM Thread Starter
BNovak
BNovak's Avatar
Just wondering for the long run, or if I should look for another axle (was thinking maybe the 9" from a ford F150)
Thanks.
-BN
'97 Forest green. ~6" total lift, 8.8, etc. 36" TSL's, winch. You get the drill.
BNovak is offline
post #2 of 7 Old 03-28-2005, 08:58 PM
JSBlu974X4
if 31 spline yes, i wouldnt be too crazy on the pedal.
2005 Unlimited Rubicon Hard N Soft Tops, Clayton Long Arm on RE Coils, Warn Bumper/Tire Carrier, Warn Winch N Bumper, Currie Steering, JKS Quicker Disconnects, JKS Front Trac Bar, Bilsteins, CO2 System..Yada Yada Yada
JSBlu974X4 is offline
post #3 of 7 Old 03-28-2005, 09:47 PM
Chris_L
35's would be best for an 8.8. 37's would eventually kill it. If your going over 35's, look at a HP dana 60.
Buggy on 40's
Chris_L is offline
post #4 of 7 Old 03-28-2005, 09:53 PM
CreightonRea07
why not go w/ the ford 9. depending on which one you get, it can be stronger than a 60
Me:
2000 TJ Sport
Dana 44
4.0L 5-speed
33x12.50 bfg Muds
MORE sport cage
re 4.5 w/ 3.5 springs
Little Brother:
'92 Cherokee Laredo
Stock but soon to be lifted
235/75 BFG All-terrains
lots of dings and scratches
CreightonRea07 is offline
post #5 of 7 Old 03-28-2005, 09:58 PM
wipedawg
wipedawg's Avatar
also the 9in isn't near as chubby as the d60
Silver Jeep Club Member # 829.3
6 in lift, 35" Interco Trxus MT's, long armed, Bushwacker cut-out flares, Skyjacker coils(powdercoated grey), RE 4.5 extreme duty leaf packs, Tera 1.5in shackles, AJ's Superrails, AA SYE, TW DS, Blacked out all around. and a buncha RE trackbar stuff, and the infamous ZJ tierod :)
wipedawg is offline
post #6 of 7 Old 03-28-2005, 10:06 PM
Chris_L
Hmmm....mine has more clearance than a 9"
Also the HP 9" carries an 8.8 ring gear and is not a true 9". The low pinion nine hangs like a boat anchor.
Buggy on 40's
Chris_L is offline
post #7 of 7 Old 03-29-2005, 07:46 AM
jc97xj
You can get a true high pinion 9 that does not use 8.8 gears.
http://www.truehi9.com/
04TJ X
12JKU Rubi
jc97xj is offline
d30 vs d44 w/37's Bucket110 TJ Wrangler Technical Forum 25 05-31-2011 07:45 PM
Got my 37's Brent_f70 JK Wrangler Technical Forum 26 06-01-2009 10:44 AM
What do I need to fit 37's Shinobi YJ Wrangler Technical Forum 5 11-13-2008 04:45 PM
37's on a D30 Chris @ GATR TJ Wrangler Technical Forum 19 12-14-2007 10:03 PM
4.5'' and 37's ? spittindurt TJ Wrangler Technical Forum 2 12-27-2006 09:02 AM
