Camshaft Removal? - JeepForum.com
post #1 of 10 Old 06-18-2009, 03:37 PM Thread Starter
newagecustoms
Camshaft Removal?
How do you remove the camshaft after you remove the distributer cap and timing chain and the rockers and pins out. is there a nut or something holding it in? Do i need to drop the trans.? help
newagecustoms is offline
post #2 of 10 Old 06-18-2009, 03:54 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Did you remove the distributor drive gear?And no you don't have to drop the trans.
GOLENJEEPTJ is offline
post #3 of 10 Old 06-18-2009, 05:07 PM Thread Starter
newagecustoms
i removed the dis. cap and the shaft it was connected to which holds the gear.
post #4 of 10 Old 06-18-2009, 05:57 PM
GOLENJEEPTJ
Mind you this is out of a 2002 FSM. But it should help!
REMOVAL - CAMSHAFT
WARNING: THE COOLANT IN A RECENTLY OPERATED
ENGINE IS HOT AND PRESSURIZED.
RELEASE THE PRESSURE BEFORE REMOVING
THE DRAIN ****, CAP AND DRAIN PLUGS.
(1) Disconnect negative cable from battery.
(2) Drain the cooling system (Refer to 7 - COOLING
- STANDARD PROCEDURE).
(3) Remove the radiator (Refer to 7 - COOLING/
ENGINE/RADIATOR - REMOVAL) and condenser
(Refer to 24 - HEATING & AIR CONDITIONING/
PLUMBING/A/C CONDENSER - REMOVAL), if
equipped with A/C.
(4) Remove the engine cylinder head cover (Refer
to 9 - ENGINE/CYLINDER HEAD/CYLINDER
HEAD COVER(S) - REMOVAL).
(5) Remove the rocker arms, bridges and pivots
(Refer to 9 - ENGINE/CYLINDER HEAD/ROCKER
ARM / ADJUSTER ASSY - REMOVAL).
(6) Remove the push rods.
(7) Remove the engine cylinder head and gasket
(Refer to 9 - ENGINE/CYLINDER HEAD - REMOVAL).
(8) Remove the hydraulic valve tappets from the
engine cylinder block (Refer to 9 - ENGINE/ENGINE
BLOCK/HYDRAULIC LIFTERS (CAM IN BLOCK) -
REMOVAL).
(9) Remove the vibration damper (Refer to 9 -
ENGINE/ENGINE BLOCK/VIBRATION DAMPER -
REMOVAL).
(10) Remove the timing case cover (Refer to 9 -
ENGINE/VALVE TIMING/TIMING BELT / CHAIN
(11) Rotate the crankshaft until the crankshaft
sprocket timing mark is aligned on centerline with
the camshaft sprocket timing mark (Fig. 32).
(12) Remove the timing chain and sprockets (Refer
to 9 - ENGINE/VALVE TIMING/TIMING BELT/
CHAIN AND SPROCKETS - REMOVAL).
(13) Remove the front bumper and/or grille, as
required.
(14) Remove the two thrust plate retaining screws,
thrust plate and camshaft (Fig. 31).
post #5 of 10 Old 06-18-2009, 08:18 PM Thread Starter
newagecustoms
Do you have a diagram?
post #6 of 10 Old 06-19-2009, 04:30 PM Thread Starter
newagecustoms
ok i got the cam out!!! thank god but i cant get the bearings out. you have to have a special tool, dont you?
post #7 of 10 Old 06-19-2009, 04:33 PM
GOLENJEEPTJ
You really should reconsider getting a rebuilt or someone to build this right? Taking apart is one thing,putting back together right is another.You should also invest in a FSM? Good Luck!
NOTE: It is not advisable to attempt to replace camshaft
bearings unless special removal and installation
tools are available, such as recommended tool
8544 Camshaft Bushing Remover Installer.
(2) Using Special tool 8544 Camshaft Bushing
Remover Installer, remove the camshaft bearings.
post #8 of 10 Old 06-20-2009, 01:39 PM Thread Starter
newagecustoms
anyone know where i could get such a tool?
post #9 of 10 Old 06-20-2009, 07:05 PM
wushaw
Rockin jeep
wushaw's Avatar
wushaw is offline
post #10 of 10 Old 06-21-2009, 10:49 AM
GOLENJEEPTJ
Originally Posted by wushaw View Post
Site is down, being upgraded, no tool shown right now.
Bad camshaft in some 04 TJs PackMan TJ Wrangler Technical Forum 4 01-22-2012 12:34 PM
grill/camshaft removal question grimjeeperyj14 YJ Wrangler Technical Forum 1 12-29-2009 07:45 PM
2.5L Camshaft? jaybird02 TJ Wrangler Technical Forum 1 03-19-2008 09:44 PM
99 TJ Camshaft docque TJ Wrangler Technical Forum 2 06-20-2006 10:52 AM
Camshaft Joeys97TJ TJ Wrangler Technical Forum 8 05-31-2006 03:05 PM
