Camshaft position sensor? - JeepForum.com
post #1 of 2 Old 08-15-2009, 06:50 PM Thread Starter
wolfstyle
I put a mml on and had hit the camshaft position sensor in the process. After I got everything back together I had a SEL come and the code was P0016 which is a CPS. I bought a new one and installed it. I cleared the code and went for a drive but not even 2 miles down the road and the code was back. The jeep seems to drive fine with the code the only differences I noticed is I can't go over 3K rpm because the engine acts like I hit the rev limiter and the cruise is disabled. So now I'm not sure what to do. Any help would be much appreciated.
Thanks,
wolfstyle
wolfstyle is offline
post #2 of 2 Old 08-16-2009, 07:40 AM
mobyjeep
Are you sure you need a Cam position sensor? Maybe you need a Crankshaft position sensor.
mobyjeep is offline
Crankshaft Position Sensor or Camshaft Position Sensor? TennesseeTJ TJ Wrangler Technical Forum 20 07-31-2017 12:22 PM
Camshaft position sensor 94 YJ 2.5L FI ChiroSean YJ Wrangler Technical Forum 5 11-01-2008 05:55 PM
camshaft position sensor? LeftoverSalmon TJ Wrangler Technical Forum 7 07-08-2008 11:01 AM
Does 97 TJ have Camshaft Position Sensor? spdrmn44 TJ Wrangler Technical Forum 2 08-30-2007 04:40 PM
??where is the CAMshaft position sensor on 02 tj?? 02tjsport TJ Wrangler Technical Forum 1 06-11-2007 01:11 PM
