Camshaft Position Sensor? - JeepForum.com
post #1 of 4 Old 07-08-2009, 08:50 AM Thread Starter
04TJSport
Mine went out yesterday and i took one out of a WJ and now it starts but the motor is now missing and sounds like crap is there a way to adjust the sensor or something i had to put the one from the wj in till my new comes in from the states it sucks being in germany and no parts stores. i'm going to replace the spark plugs tonight and see if that helps but is there anything else i can do there are no codes.
" All Out of Road" Vilseck Jeep Club
04 TJ 3 in. BL 2in. CS 4.88 power inverter CAI snorkel
Silver Jeep Club Number 23
04TJSport is offline
post #2 of 4 Old 07-08-2009, 09:02 AM
steve2n
Location: SE Michigan - never be afraid to ask for a tow
I had to "tweak" mine after doing a cam swap... I had the whole assembly out.
It went something like this:
- It should end up with the connector facing the back of the engine. It rotates slightly when the gear meshes with the cam shaft when the assembly is inserted.
- Since it is running you can loosen the locking clamp and rotate it while it is running. Go one way until it stumbles, go the other way until it stumbles, then set it in the middle of those two locations and lock it down.
- Do this all with the engine warmed up.
Worked for me.
steve2n is offline
post #3 of 4 Old 07-08-2009, 09:15 AM Thread Starter
04TJSport
ok i will try that as of right now it is facing the back but against the block so i will play with it some more then.
post #4 of 4 Old 07-10-2009, 03:03 AM Thread Starter
04TJSport
just an update. I put all new plugs in and replaced the spark bar with one out of a WJ and now she runs like new.
Crankshaft Position Sensor or Camshaft Position Sensor? TennesseeTJ TJ Wrangler Technical Forum 19 11-28-2015 06:27 PM
Camshaft position sensor? wolfstyle TJ Wrangler Technical Forum 1 08-16-2009 08:40 AM
camshaft position sensor? LeftoverSalmon TJ Wrangler Technical Forum 7 07-08-2008 12:01 PM
Does 97 TJ have Camshaft Position Sensor? spdrmn44 TJ Wrangler Technical Forum 2 08-30-2007 05:40 PM
??where is the CAMshaft position sensor on 02 tj?? 02tjsport TJ Wrangler Technical Forum 1 06-11-2007 02:11 PM
