camshaft position sensor? - JeepForum.com
post #1 of 8 Old 07-07-2008, 06:49 PM Thread Starter
LeftoverSalmon
LeftoverSalmon's Avatar
I cant seem to find anyplace that sells a camshaft position sensor... None of the local autoparts stores have it - only have crankshaft sensor. Even my search online has been fruitless.
Can anyone point me in the direction of one of these?
Thanks in advance.
LeftoverSalmon is offline
post #2 of 8 Old 07-07-2008, 07:20 PM
Hesher420
I recently got one for my '06 at checker. Napa also had them.
What do you got going on? No Spark?
"We are one. One society. Digitless."
"I am not a number, I am a free man!"
Hesher420 is offline
post #3 of 8 Old 07-07-2008, 07:30 PM
rebus20
I got a new cps and oil pump shaft drive installed today. You can find them on advanced,orielys or autozones website I believe. I ordered mine from the dealer. It was about $60.
rebus20 is offline
post #4 of 8 Old 07-07-2008, 07:47 PM
Gabe
Gabe's Avatar
How can you tell when yours is bad?
Originally Posted by Rubi22
Holy ****, did someone log onto Mean Fish's account and say something thoughtful?
Gabe is offline
post #5 of 8 Old 07-08-2008, 06:46 AM Thread Starter
LeftoverSalmon
Getting a 1391 cel - computer sometimes cant see camshaft or crankshaft position sensor. I was hoping to do the cam first - seems a little easier to get at than the crank pos sensor which sits on top of the tranny.
post #6 of 8 Old 07-08-2008, 08:20 AM Thread Starter
LeftoverSalmon
So Im really confused.... It would appear that no one sells a cps for a 98. Is it possibly called something else?
Every place I look has camshaft position sensors for models 00 and over but nothing for a 98. Do I have to replace the entire distributor? That would be a pisser for a little sensor that prolly doesnt cost more than $30.
Anyone with older TJ's been able to find one?
post #7 of 8 Old 07-08-2008, 10:47 AM
Varnish
Varnish's Avatar
Based on napaonline.com I come up with "Distributor Pick-up Assy" ECHMP847
This sensor can be tested by looking for a fluctuating 5 volt signal as the engine turns over - described in this thread:
http://www.jeepforum.com/forum/showt...=camshaft+test
The crankshaft position sensor wasn't too bad to change out on my '98 auto, heck of a lot better than my grand cherokee was, hopefully your ax15 is similar.
'98 TJ, '06 LJ, '88 YJ
Varnish is offline
post #8 of 8 Old 07-08-2008, 11:01 AM Thread Starter
LeftoverSalmon
Thanks a bunch. I just picked one up from a dealership. Probably should have looked there earlier but im not inclined to give them too much of my $.
I thought about testing the sensor but wasnt sure it would tell me anything as the problem is pretty intermitent. It generally doesnt throw the code until I hit 2000 rpms.
Thanks for the responses.
Crankshaft Position Sensor or Camshaft Position Sensor? TennesseeTJ TJ Wrangler Technical Forum 19 11-28-2015 05:27 PM
Camshaft position sensor? wolfstyle TJ Wrangler Technical Forum 1 08-16-2009 07:40 AM
Camshaft position sensor 94 YJ 2.5L FI ChiroSean YJ Wrangler Technical Forum 5 11-01-2008 05:55 PM
Does 97 TJ have Camshaft Position Sensor? spdrmn44 TJ Wrangler Technical Forum 2 08-30-2007 04:40 PM
??where is the CAMshaft position sensor on 02 tj?? 02tjsport TJ Wrangler Technical Forum 1 06-11-2007 01:11 PM
