Camshaft - JeepForum.com
post #1 of 9 Old 05-31-2006, 12:31 PM Thread Starter
Joeys97TJ
Camshaft
I was wondering if anyone knew the part number of a replacement camshaft for a 1997 TJ 4.0L I6? Or, know of a performance alternative? Thanks.
Joeys97TJ is offline
post #2 of 9 Old 05-31-2006, 01:01 PM
paroxysym
2007 WK
mopar performance stage 2 camshaft/lifters.
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #3 of 9 Old 05-31-2006, 01:06 PM
wil badger
Cranecam makes several cams for the 4.0
wil badger is offline
post #4 of 9 Old 05-31-2006, 01:13 PM
paroxysym
2007 WK
they do but they all require tuning, well some tuning to say the least. plus you have to buy lifters seperate and what not- i priced it and its almost $400 for the timing gear, camshaft, lifters, crank gear, and timing gear. the mopar kit i believe uses all stock parts, except the camshaft and lifters and cost $100 less. i paid $875 to have it installed and im happy with the results.
OEM+
post #5 of 9 Old 05-31-2006, 02:50 PM
jonballi
Got a audio clip of the Jeep idleing? I'm curious as to how lopey the Mopar Stage 2 cam is.
jonballi is offline
post #6 of 9 Old 05-31-2006, 02:55 PM
merfsiu
merfsiu's Avatar
What are the results?
merfsiu is offline
post #7 of 9 Old 05-31-2006, 04:01 PM
kenskis
This months issue of "JP" discusses this issue, in a good article that also sparked my interest in other expereinces with high performance camshafts. Look in JP for more info.
|______
|l ,[____],
l---L –OlllllllO-
()_)-()_)--o-)_)
Red 03 TJ sport l OME lift l ARB's front & rear l 4.11 gears l 32X11.50" MTR's l Nth Degree Tummy Tucker l SYE & CV l Nth Degree Dana 44 slider l Nth Degree Oil Pan Skid l JKS adjustable front track bar l KC slimlights l Rock Rails l IPF H4 headlights l Dynamat
kenskis is offline
post #8 of 9 Old 05-31-2006, 04:04 PM
97_4popper
1990 MJ Comanche
Just got the latest issue of JP last night. They just happened to do a 4.0 cam swap in that issue. Don't remember the grind, but they gained some good HP and torque. I think it was about 19HP, but; I could be wrong. Memory ain't what it used to be.
Check it out.
97_4popper is offline
post #9 of 9 Old 05-31-2006, 04:05 PM
97_4popper
1990 MJ Comanche
You're faster than I am.
Bad camshaft in some 04 TJs PackMan TJ Wrangler Technical Forum 4 01-22-2012 01:34 PM
Camshaft Removal? newagecustoms TJ Wrangler Technical Forum 9 06-21-2009 11:49 AM
2.5L Camshaft? jaybird02 TJ Wrangler Technical Forum 1 03-19-2008 10:44 PM
camshaft replacement in 4.0 bigrobby YJ Wrangler Technical Forum 2 09-04-2007 11:42 PM
99 TJ Camshaft docque TJ Wrangler Technical Forum 2 06-20-2006 11:52 AM
