Cam bolts to set caster - where to buy? - JeepForum.com
post #1 of 27 Old 12-19-2011, 02:03 PM Thread Starter
mhopton
Just came from the alignment shop and I need to have the caster adjusted. It is currently at 4.5deg while running 265/75/16 tires, basically a 32" tire. My research suggests it should be about 6deg and that the low number is contributing to the "wandering" and tracking issues on the highway.
Anyone know where I can get the cam bolts and washers? Quadratic only has them for the rear UCAs.
Thks
mhopton is offline
post #2 of 27 Old 12-19-2011, 02:09 PM Thread Starter
mhopton
Will also note that the cross-caster measurement was within .5 deg.
mhopton is offline
post #3 of 27 Old 12-19-2011, 02:30 PM
j-nut
NAPA sells them. i had to look them up myself and show the guy that worked them, who by the way was the owner or that particular store, how to find it. they may tell you it is something they dont carry casue they never have seen them. here is the part number just to make it easier #NCP 2643693
j-nut is offline
post #4 of 27 Old 12-19-2011, 03:40 PM
Gary2
Ebay also
Gary2 is offline
post #5 of 27 Old 12-19-2011, 03:49 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Zone Off-Road sells em.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #6 of 27 Old 12-19-2011, 04:57 PM
STIFLER
your profile says 2" BDS kit.... I can't imagine you are far enough off on castor to make that much of a difference.
0311/2531 USMC YUT
STIFLER is offline
post #7 of 27 Old 12-19-2011, 06:57 PM Thread Starter
mhopton
Like I said, I'm at 4.5deg versus spec of 6-7. Is that not enough to make a difference? Believe me, I'd rather not mess with it - that's for sure!
Thanks for the buying locations.
mhopton is offline
post #8 of 27 Old 12-19-2011, 06:59 PM
Unlimited04
you'll definitely notice it.
Useful Write-Ups:
Funny:
post #9 of 27 Old 12-19-2011, 08:03 PM Thread Starter
mhopton
Great. So, next question, what is the best way to go about measuring the caster once the cam bolts are installed? I've searched the "end all be all alignment thread", but am not finding a good "how-to". Advice on this?
thanks
mhopton is offline
post #10 of 27 Old 12-19-2011, 08:07 PM
Gary2
with the jeep level I put a digital angle finder on the bottom of the " C" like at the ends of the axle tubes near the lower ball joint . you will need to double check your toe in when you finish
Gary2 is offline
post #11 of 27 Old 12-19-2011, 08:27 PM
Unlimited04
thanks
another alignment from the same shop as before. you'll need to reset toe after resetting caster because the angle of the knuckles changes slightly. with cam-bolts, they only get you ~1.5 caster max in either direction, so just max out the cam toward the front the vehicle to effectively "lengthen" the lower control arms. That should put you about 5.5-5.8 if you were at 4.5 before.
i've tried several tricks to measures caster on two different axle housings...the socket on the upper ball joint, the u-joint, the lower C like Gary2 described...and nothing has given me repeatable results. By repeatable, I mean I take the angle finder off and put it back on 10 minutes later or 10 days later, and don't get the same result - and none of them are the same as what the laser alignment rack at Firestone said. However, the u-joint has been the most linear delta...meaning u-joint says X, and the alignment rack says Y...so if I move it by +1, I can measure at home and figure X+1, and know with fair certainty the alignment rack will say Y+1.
That's why I bought the Lifetime Alignment from Firestone, and when I want to know my alignment specs, I drive over there when they're not busy. Takes 20 minutes, I don't have to get dirty, and they give me a cool print-out. I've been in over 8 times in the past few years...
Useful Write-Ups:
Funny:
post #12 of 27 Old 12-19-2011, 08:41 PM Thread Starter
mhopton
Unltd, that's exactly what I needed. The ones I saw on fleabay said they maxed at 1.5deg, so my assumption was that maxed in one way, or the other and given a 4.5 deg starting point, I'd either be at 3, or 6. Six would be probably perfect. Would 1.5 deg significantly change the pinion angle?
And, I bought the 1-year alignment from Kauffman...just to get the caster sorted.
Thks
mhopton is offline
post #13 of 27 Old 12-19-2011, 08:48 PM
Unlimited04
Thks
you'll be fine on pinion angle, no problem.
Useful Write-Ups:
Funny:
post #14 of 27 Old 12-20-2011, 06:42 AM Thread Starter
mhopton
Picking these up at Napa today and will install them tonight. Back to the alignment shop tomorrow to finally be right.
mhopton is offline
post #15 of 27 Old 12-20-2011, 06:52 AM
STIFLER
do you plan on ever increasing the amount of lift? I know it is a lot more $$$ but adj CAs would give you what you are looking for and give you options down the road. just a thought....
0311/2531 USMC YUT
STIFLER is offline
